Bigger fuel tank for a civic vx ? - Page 3 - Fuelly Forums
Old 05-04-2012, 09:27 AM   #21
Re: Bigger fuel tank for a civic vx ?
I frequently had 500-600 mile tanks in my 95 VX. I had the 10-gallon tank. I had one tank of 680+ miles (77 mpg on the fillup). Spectra Premium makes a 13.5-gallon tank that will fit a VX.
Old 05-04-2012, 11:35 AM   #22
add|ct's Avatar
The most I could fit in our 92 VX(canadian made/canadian model VIN), was about 10.5 gallons; while the car's passenger side was lower than the spout at the gas cap. So, level ground 10 gallons seems to be reasonably what this tank is. I have a hard time believe it is 'truly' a 12 gallon tank since it cuts off 2 gallons short. A true 12 wouldn't need 2 gallons of 'top off' near bone-dry. We're not talking about the normal 'top off in stages and potentially flood your EVAP system either).
'92 Civic VX, Canadian model
Old 05-04-2012, 08:07 PM   #23
sebass's Avatar
THANK YOU ADDICT! I was and still am thinking the same thing, that MY 92 VX has 10 gal tank. One I filled it up to top with 8.5 gals while needle was on E so i figured another 1.5 as what was left inside. No way with 12 gal tank i would be on E. That's extra 3.5 which would be 1/3 or 1/4 of tank (depending what u think you have). NO WAY!!!
Sorry Arky. VX have 10 gal tanks so if you're sure you put in 12.xx gal u have custom tank installed by Chris.
sebass is offline   Reply With Quote
Old 05-04-2012, 09:09 PM   #24
VX_Arky's Avatar
Check my gas log. I've put well over 12 gallons in my tank. If Chris put a custom tank on it, that's great. The more gas I can carry, the further I can go!! A couple of extra gallons isn't going to hurt FE.
VX_Arky is offline   Reply With Quote
Old 05-05-2012, 10:57 AM   #25
VX_Arky's Avatar
When you going to post some pictures of that jelopy, Seabass?
Old 05-05-2012, 11:04 AM   #26
sebass's Avatar
Eventually i will.
Old 05-05-2012, 05:30 PM   #27
add|ct's Avatar
^Well, ya got me beat on paint job and antenna! lol, my VX still needs a bit of work. Ugh!
Old 05-05-2012, 07:57 PM   #28
The tank in Arky's is the factory tank. I can't see any reason you couldn't put the larger tank in any year vx. The chassis are identical for the 92-95 hatchbacks as far as I know.
I exit lean burn when my life is at risk.
1998 Odyssey 24.1 mpg average
1984 crx project now on the road
hondaguy72 is offline   Reply With Quote
Old 05-06-2012, 05:58 AM   #29
The US 92 VX has a 11.9 gallon tank. The fuel gauges suck. I have had 4 civics with that tank. They all read empty with about 3 gallons left. The 93-95 VX has a 10-gallon tank. I could overfill mine to 10.2 if it was bone dry.
Old 05-06-2012, 10:00 AM   #30
sebass's Avatar
Addict probably not. I took the pic from best side. My body work and paint needs some work done. Trust me
Find friends disappears after adding a friend tggbenz06 Fuelly Web Support and Community News 2 08-30-2008 05:14 AM
Some avant-folk I produced... repete86 General Discussion (Off-Topic) 7 05-09-2007 08:41 PM
