Best Spark Plugs for Ford Focus - Fuelly Forums
Old 06-19-2008, 08:01 AM   #1
I have a 2005 Ford Focus with a 2.0l duratec engine. What would be the best sparkplug for the sake of FE. The plugs are due for a change.
windyridge89 is offline   Reply With Quote
Old 06-19-2008, 09:06 AM   #2
Doesn't the focus have 100,000 mile platinum plugs installed from the factory? I'm thinking if you need plugs this soon there is something else wrong with the car.
Old 06-19-2008, 09:54 AM   #3
Most if not all cars now come with platinum plug in them and they will usually last 100,000 miles or more, but I have had a couple go bad shortly after putting in new ones, just faulty plugs I guess. I always use platinum plugs simply because they don't have to be changed as often and they don't cost much more than regular copper core plugs. Most of the time I use Bosch, but I have used AC and Autolite too and can't say as there is much if any difference. Whatever you use be sure to put anti seize on the threads to keep them from seizing up in the aluminum and stripping the threads out. I used to not use it until I stripped the threads out of one of the holes a few years ago. It is money well spent.
Hipermiler
#47 on my way to #1
Old 06-19-2008, 11:02 AM   #4
I'd stick with OEM plugs. I always use the AC Delco Platinum plugs. I even run the AC Delco 100,000 mile platinum plugs in my 81 Buick and my 86 C-10, even though they were not originally installed new. You can't go wrong with OEM ignition parts. As a side note I'd like to mention that I only buy distributor caps and plug wires at the dealer as well.
Old 06-21-2008, 12:53 PM   #5
Thank you guys. My focus has over 110k I think its time to change them out to keep everything running smoothly. Just wondering if there was a plug out there that gave a little increase in fe over others. i guess i will stick with oem
Old 06-21-2008, 04:35 PM   #6
cfg83's Avatar
windyridge89 -
It's hard to tell you what will be right for your car because I don't have the same make, . If I were you I would find a "Ford Focus" owners forum. I use www.saturnfans.com for drivetrain-specific questions, and come back here to tweak for MPG.
Oregon-Washington: Winter gas ending, summer gas formula starting? 740dan General Fuel Topics 5 02-26-2013 10:17 PM
miles between fuelup limit? drnknmnky13 Fuelly Web Support and Community News 6 09-14-2010 04:08 AM
What's you household FE? zpiloto General Fuel Topics 10 11-13-2007 09:29 PM
pulse up or pulse down a hill, higher or lower gear perris Hypermiling 9 07-16-2007 10:33 PM
Drafting behind a Truck GasSavers_roadrunner Hypermiling 20 12-24-2006 12:17 AM
