belly pan teaser pic - Page 2 - Fuelly Forums
Old 11-12-2006, 09:43 AM   #11
Yes , on some cars that I have seen where theres lots of plastic-work on the back it acts like a huge air scoop.
It just cant be good for air flow.
Old 11-12-2006, 10:41 AM   #12
Originally Posted by JanGeo
MAN I am definately going to get under mine this winter when I get into the garage and so some belly pan work. Mostly in the rear where the rear lowers are hanging and the fenders are wide open to all sorts of weird air flow. I may even do a hidden front grill block that can be remotely opened and closed by cable. One problem I found out about last winter is that as you make the gas mileage go up the amount of heat available for the cabin goes down.
Hmm, I've noticed a bit differnt than this, my nearly air tight radiator inlet(*) makes the car warm up a little faster, Than again this has never been a problem for me, it's the difference between heat after one mile, and turning down the heat after a mile of driving haha. (V-8's make a lotta warmness)
(*)-2 1.4 in. diamter circles between the headlights are the only openings infront of the radiator, I can't understand how it doesn't over heat? unless it's sucking air from behind the radiator through it, and than being sucked back by the fan? passing through the radiator twice?
Old 11-12-2006, 11:08 AM   #13
lovemysan's Avatar
More things I've noticed about the belly pan. The engine stays warmer longer when sitting in parking lots. The engine stays closer to actual advertised thermostat opening temps. It makes my HAI more efficient than previously noticed. The engine sounds much more refined than before with doors or windows open.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 11-12-2006, 02:06 PM   #14
Yeah I ran my heater while parked last winter and watched the engine temp drop to 160 from 182. I also have noticed that the hood is insulated but the gap on the edges lets the heat out and the right fender also gets warm after I shut it down. A couple of weather strips under the hood should really seal it up nicely and prevent some of the dirt from getting in on the engine. I didn't mean that a grill block would reduce the heat - I mean making the engine more efficient makes i tburn less gas and take longer to heat up.
Old 11-12-2006, 07:12 PM   #15
nonnef's Avatar
How much quieter would you say it is now? An extremely noticeable difference to no-pan?
nonnef is offline   Reply With Quote
Old 11-13-2006, 05:48 PM   #16
cfg83's Avatar
lovemysan -
Thanks for the pix. I really like the overall fit and finish. The accidental close-up of the front grill block is also an added perk.
Old 11-13-2006, 06:33 PM   #17
lovemysan's Avatar
That grill block was my second attempt at cutting coroplast. Man that stuff is annoying.
I would say that there is no difference in engine noise on the interior of the car. When the windows are down, door open, or walking around the car. You no longer hear valve train noise and the general sohc saturn rattles. I'm not sure if I'll finish the pan or not. I'm working on the side skirts tonight see the other thread for those pics
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-14-2006, 10:59 AM   #18
Good to see a good use of backup jacks in case the blocks fail.
I had a car fall off a jack onto me once - not fun at all.
Old 11-14-2006, 11:05 AM   #19
I've noticed this too. I rarely start my engine "cold", and when I have to (no EBH outlet), I hate the way it sounds & feels while it warms up. A warm engine is a happy engine.
Old 11-14-2006, 02:18 PM   #20
lovemysan's Avatar
Makes you think about changing the oil doesn't it. I just close my ears and think "its just a noisy engine there made that way"
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Add driver to car already in garage, for shared car ssquid Fuelly Web Support and Community News 1 01-05-2013 01:10 PM
Joint Membership with GasBuddy? Badams Fuelly Web Support and Community News 2 07-01-2011 11:14 PM
Browse by MPG, etc pixelwiz Fuelly Web Support and Community News 1 08-12-2008 12:26 AM
IAT Sensor Mod (Resistor Mod) SVOboy General Fuel Topics 28 10-17-2005 06:08 PM
Got my headers today & question 'bout crank scrappers b1gmoose General Fuel Topics 8 10-08-2005 09:49 PM
