popimp -
Originally Posted by popimp
I bought some resistors so I could try it on my van. What's the ideal inlet air temp? Outside is 90F while driving I was getting about 110F-115F IAT. The resistors I got were 100, 150, 220, and 330 ohms. Any thoughts on a Dodge Van using this?
I did a quick google and found this :
IAT sensor hack
http://www.dodgeforum.com/m_152375/tm.htm
The above thread is not talking about a Caravan, but I would think that Dodge's share the same sensors. That thread led me to this :
http://www.hurricane-horsepower.com/
Which has this cool picture (for Toyotas!
http://www.hurricane-horsepower.com/...-emissions.gif
But, it looks like the gizmo is designed for HP, not MPG,
. It would be worth asking them if the dial "goes the other way".
Anyway, if I were you I would :
1 - idle the car in the driveway with each resistor attached and observe the IAT temperature using the scangauge. Then you will have a "map" of resistor to temps for your IAT sensor. Since you would only be idling, aka 0 load, you would be able to "map" the resistors.
2 - Since you already know the "normal" IAT temps, add a resistor that adds maybe +30 degrees to the 110-115 degrees you are seeing and see what happens. If you do a test similar to mine, you should be able to make some kind of conclusion as to whether the scangauge is reporting the same response.
When Cheapybob did his tests with real HAI temps, everything seemed to work until around 180 degrees F. The question is, what are the little black boxes (ECU/PCMs) doing similar or
differently?
What do other people think?
