Awesome - cat failure - Page 2 - Fuelly Forums
Old 01-24-2009, 11:52 AM   #11
i'm curious to know if an equal length header could increase FE as well as power a bit. its more targeted at eliminating an inefficiency in the exhaust system so i suspect it could help a tad, but would be good to test
zero_gravity is offline   Reply With Quote
Old 01-24-2009, 02:48 PM   #12
They can do if not oversized.... but that basically means making your own.
Old 01-26-2009, 12:37 PM   #13
Send a message via AIM to jeep45238
In a very limited RPM range, yes. For a daily driver in city I don't see much of a benefit. For highway, I see your R&D costs more than shadowing all gains you may receive.
Democracy is two wolves and a sheep deciding what to have for dinner. Liberty is a well armed sheep contesting that decision.
jeep45238 is offline   Reply With Quote
Old 01-30-2009, 08:33 AM   #14
kamesama980's Avatar
if the tubes aren't too large dia, yes almost any header will benefit over the factory cheap-as-we-can manifold. how much depends on how bad the factory manifold is
-Russell
Old 01-30-2009, 09:03 AM   #15
If I had a car that would take any of the cheap headers floating around on eBay, I might consider getting one and flattening it a bit. This would increase the surface area to volume ratio though and would require good heat wrap to avoid exhaust gas velocity loss from cooling. For example a cheap tubular header with 1.5 inch primaries would be much improved for outputs less than 50HP a cylinder or so by squishing it down to 3/4" in one dimension along most of it's length. I'd pack it with damp sand or similar substance while I was hammering at it, or using clamps on it, and be careful not to stress joints which may crack.
I'm considering getting an older factory header for Wile-E at some point pre-91 Escort GTs with the 1.9 motor came with them. However, I'd need to relocate the cat, get an O2 bung welded in and tweak it a little... so I'm probably not going to try it until I'm needing a new cat. Which I hope shows itself starting to weaken on an emissions test before it's a complete fail (Don't wanna be under pressure to get it done in a couple of days after a fail)
Old 02-02-2009, 05:37 AM   #16
same problem here, nothing on ebay or anywhere for that matter. might try to make one some day when i get bored.
Add Groups? ScoutTech Fuelly Web Support and Community News 3 03-17-2010 11:35 PM
Split personalities R.I.D.E. General Fuel Topics 26 10-13-2008 07:47 PM
Civic EX with VX swap mrmad General Maintenance and Repair 5 12-03-2007 04:23 PM
CL 1993 Geo Metro XFi GasSavers_Red For Sale 2 08-06-2007 05:30 PM
I have discovered injector off coasting! SVOboy Transmissions and Running Gear 13 05-15-2006 08:01 PM
