Aveo - Page 2 - Fuelly Forums
Old 10-05-2006, 04:54 AM   #11
Yeah, even the Automatics Disappoint
I've rented the automatic sedan version twice and had the same disappointing FE. Even the gearing in that was short -- from a stop: ka-pow you've inadvertently given it too much throttle, the soft suspension squats in the rear, and it takes off. On the highway, the tach reads unbelievably high.
Review Link.
My half-brother bought the 5-door, 5-speed when they first came out. His father worked for GM for like 100-years, so he ended up with rebates and the family discount, which brought the out-the-door total to sub $10k. He has a long daily commute at 55-60 mph in rural Upstate New York, and he hasn't had any complaints so far.
When I drove it, the biggest plus was the micro-car handling.
Old 10-05-2006, 01:16 PM   #12
omgwtfbyobbq's Avatar
Whoa, the xB doesn't seem to be ~3300lbs. Full sized Camrys are barely that.
Old 10-06-2006, 04:58 AM   #13
GasSavers_brick's Avatar
Isn't the Aveo some kind of re-badged Daewoo or something? It looks like a nice enough car from the outside but I tend to confuse it with the Susuki Aerio (or however you spell it). Actually, maybe that's what it is?
It's so irritating that manufacturers (even Honda! with the US-spec Fit!) blow highway FE with too high of a final drive ratio. I realize why they are doing it (available power, avoiding complaints about the car feeling like a dog) but there has to be a better way.
'07 Toyota Prius
Old 10-06-2006, 05:02 AM   #14
Yup. Which cracks me up with their slogan "American Revolution".
Old 10-06-2006, 05:32 AM   #15
Agreed! And the better way is simple: an optional, taller final gear for those of us willing to SHIFT occasionally when needed for acceleration or hill climbing at top gear speeds.
For the masses who apparently aren't willing to ever shift out of top gear once they get there, fine. Stick with the "original" too-short gearing.
EDIT: of course this option puts the onus on the sales people to adequately explain the pros and cons of each choice, and that's where the idea falls on its face.
Old 10-06-2006, 05:41 AM   #16
Perfect
Originally Posted by MetroMPG
Agreed! And the better way is simple: an optional, taller final gear for those of us willing to SHIFT when needed for acceleration or hill climbing at top gear speeds.
Exactly. So, put in a slushbox so people can drive it here. Classic PRNDL shift pattern. People use "D" and that's about it. BUT
Put a curious button somewhere that says "Economy". When pressed, the dash indicates "Economy" in green or something. Meanwhile, behind the scenes, the highest gear is now available and it shift's into a taller gearset at higher speed cruise. Normal operation ensues. Shut the car off, and like cruise control it resets. So you can go back to "D" and forget about stuff until you pass the gas station prices and "Hmmm, might as well press the "Economy" button today".
Verify your tripmeter/odometer accuracy... jcw74801 General Fuel Topics 15 11-10-2012 03:29 AM
Add an "ignore fuel up" feature MD1032 Fuelly Web Support and Community News 5 03-03-2012 11:48 PM
How do I start? Enter my first fuel up? thirtythreedragons Fuelly Web Support and Community News 2 10-07-2009 07:18 AM
WTB: Honda Insight GasSavers_McGee Wanted to Buy 13 07-23-2007 02:19 PM
A Giblet of Friendly Advice SVOboy General Maintenance and Repair 12 08-02-2006 12:35 PM
