Way back when I worked in the truck shop one of the regular owner drivers had only one leg. His truck had a 4 speed auxilary transmission with a low low. I am pretty sure he never used the clutch very much
. It was such a low gear you could actully easily start the engine with the truck in gear. I never really learned all the details of how he managed but he seemed to do quite well. A big old Cummins could pull very well at idle rpm so he may have used the clutch to start out sometimes too. You could actually bump some of those into gear with the engine idling and the truck stopped.
The shift splits are set up pretty even so you will have almost the same rpm drop every shift. The show offs would use the engine compression brake to drop the rpm quicker. That had the potential for some rough shifts.
Even 30 years ago many of the shifts were air assisted. That made for quick shifts with little grinding. A few shifts had synchros, most did not.
It is fun to play around but I use the clutch.
I have read somewhere that truckers feel when they master clutchless shifting it is actually easier on the tranny?!?
