Another reason for better summer mileage, and a question. - Page 2 - Fuelly Forums
Old 03-13-2007, 02:39 PM   #11
omgwtfbyobbq's Avatar
Thanks for the info everyone. I'm trying to figure out how much of a range I have to work with when trying out the pot mod... I have knock sensors, and my ECM can retard timing if needed, but I'd still like to be able to adjust to the current temp.
Old 03-13-2007, 04:22 PM   #12
DRW
oh OK, so you're looking at max/min expected temps?
For max temp I'd plan for around 250*f, or slightly more if you want to play it safe. Min temp? How cold does it get out there?
Dave W.
Old 03-13-2007, 04:39 PM   #13
Naw, I'm lookin' for the average IAT compared to outside temps at cruising speeds, which seems to be ~(0-20)+outside temp. Which is pretty nice imo... Although I think I may have found a much better mod.
Old 03-13-2007, 04:43 PM   #14
zpiloto's Avatar
It would be nice if you could go the other way with it, make it cooler. In the summers here when the OAT(outside air temp) gets to 95-100 F the IAT gets to hot and the timing is affected.
Old 03-13-2007, 06:45 PM   #15
I've heard the engine is particularly resistant to detonation, with a low AFR of ~12:1and conservative timing, so I may be able to run leaner w/o the ECM cutting timing. Or... There's also the option of adjusting the MAF sensor for a leaner condition, and pulling the O2 sensor plugs so the engine can't adjust fuel trim in closed loop mode.
