Another Civic VX Question - Fuelly Forums
Old 01-23-2008, 08:06 AM   #1
Been doing some trouble shooting and in the process of checking my LAF sensor operation on my 92 VX. According to the Honda shop manual and Chilton's, there is supposed to be battery voltage across the two heater wires. I'm only getting 6.7v. Battery is new and no trouble codes. The Honda shop manual said to check the G101 wire and Chilton's said to check circuit between ECU and Main relay. I've checked the circuits to ECU and all wires show continuity. Not sure of the wiring to the main relay. Any ideas?
cmlamb2vx is offline   Reply With Quote
Old 01-24-2008, 06:10 AM   #2
GasSavers_TomO's Avatar
PM me an email addy that I can reach you at. I'll send you the FSM pages relating to your problem so we can sort this all out.
Honda Civic VX Info/Links
Old 01-26-2008, 04:56 PM   #3
Turns out the black wire to ground is ok. The voltage supply wire is only giving 6.7v. There is continuity to the ECU. What should I check next?
Old 01-26-2008, 08:16 PM   #4
Any way to swap out a known good ECU to double check it?
Old 01-27-2008, 10:36 AM   #5
cmlamb2vx - I responded to your PM with some more info But I also wanted to add that my PM was referencing page 11-49 of the pages I sent you.
Old 02-20-2008, 04:54 AM   #6
Re: Another VX Question
Originally Posted by cmlamb2vx
Just wondering....do you get 12v when you check the two nested wires on your VX? I'm still working on getting another good ECU to try swapping and checking.
Originally Posted by tomO
I'll have to try and check this weekend for you.
TomO, did you ever get a chance to check the voltage across the two nested wires on the LAF on your VX to see is you have battery voltage? Thanks.
Old 02-20-2008, 07:13 AM   #7
Sorry, I have not been able to get around to this. Some personal things have really been stirring up and a recent collector has come after me for $16K so I'm focusing on some other priorities right now. Maybe one of the other VX owners could get a reading for you since it's not too hard to do.
Let the games begin! Matt Timion General Fuel Topics 4 12-12-2021 12:04 AM
To What Extent? GeekGuyAndy General Fuel Topics 29 08-14-2007 04:19 AM
New Dodge sub-compact from China. Fuzzy5150 General Fuel Topics 45 07-16-2007 05:39 AM
GM: Petrol is Dead Silveredwings Automotive News, Articles and Products 6 06-13-2007 12:06 AM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 05:36 AM
