An oldie diesel in need of help - Fuelly Forums
Old 12-11-2021, 11:01 PM   #1
I recently started getting increased consumption on my 2.0 TDI.
The car has gone through some ECU tuning throughout its years (not by me) and now all of a sudden it has gone from rocking 6/100 to around 7.5.
Anyone has any idea what can be the cause? The sound of the car is the same and it has not lost any power.
Joseph90 is offline   Reply With Quote
Old 12-12-2021, 01:27 AM   #2
Does the car have DPF's? Sometimes diesels have to regenerate the DPF's to prevent clogging up, they do this by increasing the load on the engine to generate more heat. This also increases fuel consumption temporarily.
Depending where you live, could be atmospheric i.e. temperature decreasing, or even winter fuel blends.
Old 12-12-2021, 06:29 AM   #3
Check for a dragging brake.
Old 12-21-2021, 02:26 AM   #4
The car does indeed have DPF... Which I have never checked to be honest. I think I heard that I can clean that if I drive constantly at around 3k RPM on something like 4th gear?
https://www.youtube.com/watch?v=3F9r...hannel=TunapUK
These guys also have some tips... Do you guys agree?
Old 01-06-2022, 05:55 PM   #5
A friend mechanic also recommends that trick to keep the DPF from heavy clogging. One old guy brought his truck to the shop for the installation of the suspension and bf goodrich tires plus the alignment. My friend did that cleaning trick afterward.
visorX is offline   Reply With Quote
Old 12-21-2021, 06:43 AM   #6
Yea I mean a steady run at high revs should burn off the particulates clogging it up, if it even is that, but most cars have built in software to detect this and regen themselves.
You could remove it, but this is illegal in many places. Replacement DPF's are upwards of $1000 so it's better to maintain properly than replace.
