Aluminum Radiator, better or worse for fuel economy? - Fuelly Forums
Old 10-23-2013, 04:17 PM   #1
My 1991 Talon TSI AWD Turbo has a 2 row aluminum radiator that someone installed.
I was wondering if this is better or worse for fuel economy? I did some searching around where it is supposedly better for fuel economy but I'd think it would be worse.
Sorry to be general, but it seems that better mpg is usually achieved when the engine runs hotter?
Thanks for your thoughts.
92 Protege DX 5 speed - Poor Man's Hybrid 40.96 MPG (city)
Thicker 2 row radiator, walmart hubcaps, Pepboys tires, 10w 30 Castrol HM, Jensen CD player, Roadmaster speakers, ebay hi-flow air filter, autolite 3924 plugs, stant superstat, NGK blue 8mm wires, LeBra car bra, no Exhaust Manifold heat shield, MX-3 Seats, bad A/C compressor
jj94auto is offline   Reply With Quote
Old 10-23-2013, 04:29 PM   #2
As far as cooling goes, I don't think the radiator makes a difference. As long as it adequately cools, its fine, and makes no difference in economy. If the aluminum radiator is significantly lighter, that may make a slight difference. If you want to make the engine run hotter, do that with a different thermostat.
Old 10-26-2013, 09:24 PM   #3
Thanks
Old 10-27-2015, 07:39 AM   #4
If you are running in the city, your cooling fans should be running considerably less and for shorter intervals. I'd be happy to have it.
Quadrunner is offline   Reply With Quote
Need to update US-EPA fuel economy estimates jkp1187 Fuelly Web Support and Community News 1 03-18-2009 08:16 AM
Pulse and Glide? Pete7874 General Fuel Topics 24 02-26-2009 12:11 PM
Scanguage II out of the U.S. Erdrick General Fuel Topics 10 10-31-2007 10:40 PM
MID Install SVOboy Experiments, Modifications and DIY 33 06-04-2007 11:27 AM
