Altering alignment for mpg - Fuelly Forums
Old 04-27-2007, 06:51 PM   #1
Has anyone here changed their toe in, if that's the right term, to get better mileage? Is toe in a standard amount for all vehicles or does it change depending on the type of vehicle? Is it legal to change? Can I go to an alignment shop and have then change my alignment to something more efficient? Any success stories out there? Yes, I do understand that a vehicle becomes less stable with less toe-in.
John David
jdham137 is offline   Reply With Quote
Old 04-27-2007, 09:02 PM   #2
DRW
I checked the alignment on my car to see where it was, then made sure the toe was set at zero. The predominant feeling I get with zero toe is that the car feels 'busy' when trying to go straight on the freeway. I'm constantly correcting, the car likes to wander, doesn't want to go straight. It's just a slight tendency, nothing dangerous, only slightly noticeable. I've been driving it that way for about a year or more, it keeps me awake.
Dave W.
Old 04-27-2007, 09:10 PM   #3
Most alignment shops will refuse to go outside the specs. But, if they are willing to tweak all the way to one end of the specs for you, it can make a difference. Back when I was following early Prius stuff, the drivers were on this tightrope of wanting near-zero toe for max mpg, but also wanting some toe-in to keep a reasonable level of stability. A normal level of toe-in could cause big change in gas mileage vs near-zero toe.
Old 04-28-2007, 08:08 AM   #4
DRW and Bill,
Did you see any improvement in MPG that you can attribute to the alignment change? Changing toe-in seems like some great low hanging fruit.
Old 04-28-2007, 09:11 AM   #5
If I'm not mistaken, the Honda Insight spec is 0 for toe in. Several reviews also mentioned its on-center tendency to wander.
I noticed recently my alignment is slightly off - the wheel has to be held about half an inch (measured on the rim) off center to go straight. Must have been a pot hole.
I'd be interested in having it set to zero.
Old 04-28-2007, 02:55 PM   #6
I didn't have a Prius, I just hung out with Prius people. I have never personally seen a mileage decrease or increase attributable to alignment. But, I do think that it is important if you want to squeeze out the last bit of mileage.
Old 04-28-2007, 03:03 PM   #7
trebuchet03's Avatar
Sounds like a characteristic of zero toe
We had that problem with this year's HPV -- if you shifted your mass at high speeds (pedaling really hard), the wheels wanted to catch a new direction Even crosswinds would take advantage of the wheels searching for "straight" (given our caster and trail angles) We adjusted for .5-.75 degrees of toe in (hooray adjustable design!) and all of that went away... And our top speed did NOT change
To be honest, I'd take steering stability over fuel economy any day
11/12
Old 04-28-2007, 06:30 PM   #8
DRW
Originally Posted by jdham137 View Post
DRW and Bill,
At the time I was playing with different settings, I was doing it for better cornering, so I didn't really look at mpg. I did notice it seemed to roll easier when coasting to a stop or pushing it. It was just a coincidence that I found the best compromise in cornering and stability was with zero toe. I don't consider it unsafe; I've had my car over 110mph and there's no instability.
Of course I was being very attentive at that time too. For those moments when you want to cruise on the freeway and relax, more toe-in works better.
Anyone want to see how I built my own toe gage for $18 worth of parts from the hardware store? It seems relevent right about now.
Dave W.
Old 04-28-2007, 06:34 PM   #9
Um, yes please!
I've been thinking of making a tool using a couple of cheap laser levels. Am I close?
Old 04-28-2007, 08:41 PM   #10
DRW
wow, lasers! cool
here's how I did it. http://www.gassavers.org/showthread.php?t=3322
Dave W.
A URL parameter to expand notes please. m1sterc33 Fuelly Web Support and Community News 2 04-17-2012 07:47 AM
Will from Michigan n0rt0npr0 Introduce Yourself - New member Welcome 4 11-03-2005 01:47 PM
