Ajusting Valve Clearance this afernoon - Fuelly Forums
Old 06-22-2011, 08:35 AM   #1
Dr. Jerryrigger's Avatar
So my Subaru could just a valve clearance adjustment and I was thinking... Wouldn't it be good for FE (and bad for HP) if I set them to the largest gap recommended, or maybe a little more.
Any thoughts? How far would be too far?
Old 06-22-2011, 02:19 PM   #2
Re: Ajusting Valve Clearance this afernoon
Valve adjustment (outside spec) can only adversely affect economy. Too tight or loose will either cause the valve to hang open or give you valvetrain noise and increased wear. Keep them in spec.
I exit lean burn when my life is at risk.
1998 Odyssey 24.1 mpg average
1984 crx project now on the road
hondaguy72 is offline   Reply With Quote
Old 06-22-2011, 09:41 PM   #3
DRW
How hard is it to adjust the valves in your car?
If it's easy you have the freedom to experiment with it. I'd check all valves and see how far off they are and see how bad they need to be before you get valve tick. The engine should be able to handle slightly looser clearance as long as you keep the engine rpm lower. If the clearance is too loose it could pound the valvestem and mushroom the tip at high rpm.
Dave W.
Old 06-23-2011, 10:50 AM   #4
Well the adjusting part isn't all that hard (though I wish the threads were finer), I don't think I want to deal with doing this a second time. I had to take out the washer fluid, rad fan, bat, other stuff I'll forget to put back...
I'm only 3/4 done now, and I've been working on it all morning (I took thing apart yesterday after noon).
I've been shooting for the high end of factory spec. To make life complicated, those specs are in mm, and my tools are not, so I may be going over by up to .0003", but when I started some were over by more ten times that. I wish I had done a better job of measuring them first, as I was getting some valve tick (why I'm doing this in the first place). I'm also now wishing I had giving it a sea foam treatment (which I have never done) as now I'm worried the valves may have 0.003" of carbon on them, and that's why the valve lash was off in the first place...
Oh well, I guess that would be a good test of sea foam; to check the valve lash before and after. Maybe I'll do that in the next few week, a before and after compression test would also be nice to see. Now I'm just rambling as my back hurts, and I've avoiding finishing the job. Maybe I should have a beer....
Old 06-23-2011, 11:03 PM   #5
imzjustplayin's Avatar
apparently adjusting valve lash is something that takes practice and you shouldn't expect that you'll get good at it the first time you try it.
Old 06-26-2011, 09:11 AM   #6
Absolutely, I wouldn't recommend the job to a novice. My first valve took about 10 times as long as the last.
I worked as a machinist some time ago, which helped me with this job. Going into it I was quite comfortable measuring things to .001", with out that it would have been days of fiddling and or bad results.
Hey! Boss Man..... shatto General Discussion (Off-Topic) 0 06-27-2010 11:52 AM
Am I crazy for thinking like this? imzjustplayin General Discussion (Off-Topic) 24 10-19-2008 08:53 PM
GasSavers.org Stickers - Cheap - $4.50 shipped/pair - any color SoAngel For Sale 0 07-12-2008 10:06 AM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 09:48 AM
The medical system is bulls**t Compaq888 General Discussion (Off-Topic) 4 06-19-2006 10:06 AM
