air pressure valve caps - Page 2 - Fuelly Forums
Old 01-29-2011, 04:10 PM   #11
Re: air pressure valve caps
I am not sure if this is where I got them, but they looks exactly like this.
Old 01-31-2011, 08:24 PM   #12
Well the caps came in today along with a shipment from Hong Kong FINALLY and some other stuff from Amazon. They are anodized aluminum and very well made. I ran pressure tests with them on the 90 psi air tank and an adjustable regulator connected to a valve stem I installed into a quick change air fitting months ago . . . how DID I know I would need one of those so long ago I can't say. They are basically a pressure gauge under a plastic cap (with a tiny hole in the center) and the plunger starts to move around 25 psi and pops all the way around 36-40 psi depending upon a little friction in the unit. Looks like they should give a great indication of tire pressure dropping. The ones I got are from Victor 00703-8 and unfortunately they don't seem to have 40 psi ones. Will install them on teh rear tires after the next big snow storm that is coming. They extend 3/4 of an inch past the tip of the stem threads so they should not be too much of a problem on my wheels with the stock hub caps. The racing disks would be a problem of course since you can't see throught them!
Am I crazy for thinking like this? imzjustplayin General Discussion (Off-Topic) 24 10-19-2008 08:53 PM
GasSavers.org Stickers - Cheap - $4.50 shipped/pair - any color SoAngel For Sale 0 07-12-2008 10:06 AM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 09:48 AM
