Accent coasts poorly, but why? - Fuelly Forums
Old 03-16-2009, 10:55 AM   #1
My 2008 Hyundai Accent coasts much more poorly in neutral (it's a manual) than any other car I've owned. I was hoping it would improve after being broken in, but it persists. I live in a mountainous area, so I coast in neutral a lot and sometimes for quite extended periods (I live right on a big ridge). I asked my mechanic but he had no real suggestions as to why the coasting performance is so poor. Anyone have any ideas? I doubt it's something I can do much about, but a man can dream... Thanks.
co de pen den cy
Function: noun
Date: 1979
Old 03-16-2009, 11:07 AM   #2
GasSavers_Erik's Avatar
How about jacking up each wheel and spinning it- to check if any of the brakes are dragging.
You could try to make a belly pan to improve aero- is that rear bumper cover hollow underneath? If so, it could create a parachute effect if it is scooping up air all of the time.
Old 03-16-2009, 11:10 AM   #3
Excellent practical suggestions! The rear bumper is indeed hollow and partially exposed to form somewhat of a scoop. Maybe some sheet metal to cover that up? But how to attach it. Have to think.
Need to wait on warmer weather to spin each wheel. Still a ton of snow here in VT!
I know my snow tires coast worse than my all-weathers, but even accounting for that it still coasts badly.
co de pen den cy
Function: noun
Date: 1979
Old 03-16-2009, 12:56 PM   #4
vxdude's Avatar
Send a message via Yahoo to vxdude
the tire pressure is at its max, right?
vxdude is offline   Reply With Quote
Old 03-16-2009, 02:01 PM   #5
Yes, they are. My snow tires only have a max of 35, but the all weathers I run in the summer are more than that (the value escapes me at the moment). My previous vehicle (a Honda Accord) coasted significantly better even with winter tires inflated only to 32 psi. And it was a 1990 with 150,000 miles! Rust killed it in the end.
co de pen den cy
Function: noun
Date: 1979
Old 03-16-2009, 03:18 PM   #6
Google tells me the aerodynamic drag coefficient for that car is a respectable .31, so that's probably not the problem. At 2500 pounds it shouldn't be too light to coast reasonably with that drag coefficient.
Check the wheels for free spinning as mentioned above, not only looking for dragging brakes but also a bad wheel bearing.
Maybe there's lots of friction in the drivetrain? Thick fluid in the transmission and differential, or badly designed CV joints? That would seem to be a stretch.
Old 03-16-2009, 04:11 PM   #7
I have been trying to figure out in general why the Accent's mpg is only 32. That's worse than the Aveo and the Yaris. I notice that the automatic transmission Accent is actually rated higher than the manual one for highway driving.
co de pen den cy
Function: noun
Date: 1979
Old 03-16-2009, 04:28 PM   #8
Use the lightest weight gear lube recommended.
regards
gary
Old 03-16-2009, 06:20 PM   #9
Well that's cheap and easy to try. Cool.
co de pen den cy
Function: noun
Date: 1979
Old 03-16-2009, 08:20 PM   #10
Have a look at the handbrake (emergency brake) adjustment as well.
Sometimes they can not release fully and cause a significant amount of drag.
Easiest way is to put your finger on the hub or as close as you can get to it and feel if it is at all hot after a long coast.
Good luck , Pete.
GasSavers_Pete is offline   Reply With Quote
Tire Pressure Theory KrazyDawg General Maintenance and Repair 17 03-22-2008 01:20 AM
How The Easiest Hybrid Diy Could Be Done... trautotuning Hybrid Vehicles 20 01-31-2008 02:55 PM
Going up to you guys first: My Metro is for sale!! BumblingB For Sale 4 06-05-2007 05:52 PM
I am new and like the site alata2 Introduce Yourself - New member Welcome 3 05-29-2007 06:16 PM
Honda Exhausts: Stick with Stock? rh77 General Maintenance and Repair 7 01-10-2007 08:38 PM
