Originally Posted by skewbe
Yah, I need to look a little more closely at the kwh to lbs of CO2 conversion factor. It might be more like 1.5 lbs CO2 per kwh to the socket in the wall in the states, more like .5 lbs CO2 per kwh in ontario.
Are you assuming that the .5 gallons of warmup does not include any driving?
That's driving.
The conversion using kWh *should* yield the same results as using BTU's.
So converting 1 million BTU to kWh = 293kWh which means that's:
0.77lb CO2 per kWh anthracite coal
0.39lb CO2 per kWh methane NG
which, I will admit does seem low, but I couldn't tell you for sure....
For comparison a gallon of gas has 125,000BTU = 36.6kWh which means:
.546lb of CO2 per kWh
Given the numbers above, that does seem reasonable - it's between coal and NG.
But all that said -- you're probably right about warm days... I'll pay attention the next time I drive to see how much fuel it takes to warm up given the temps outside haven't yet gotten cold (but it's a far cry from the 90 degree summers
Of course, I've always been under the impression that power plants are more efficient (in both emissions and production) than our ICE engines
I wonder if anyone has done a study on engine wear in the winter with and without a heater....
