A/C Usage and Impact on FE - Fuelly Forums
Old 06-24-2009, 03:11 PM   #1
now that summer is here, and 3 digit temps(heat index) with it, it is suprising how much impact my car's a/c has on FE.
let me first break down a/c on vs a/c off on the scangauge. this is at standing idle only since variables are eliminated...
IGN on: 14, off: 12
LOD on: 20, off: 15
GPH on: .4, off: .2
i cannot comprehend that gal/hr is doubled at idle w/ the air on. obviously w/ throttle and driving situations the % is no where near that but...
according to SGII, there can be as much as 4mpg difference in the same trip, EXACT conditions. i ran the air on the way to work the past 2 days yielding ~36 and 37 mpg. typically i'll get ~40-42 air off.
i am accounting for a bit a variables, so i dare not claim a 6mpg difference. remember, everything has been nearly exact and the same--route, weather, breeze(none), etc. typically, this time of year, my only variables are traffic lights. i time them very well, and usually make them all but 1 or 2.
so, at 2mpg, the loss is ~5%, and 4mpg it is ~10%. maybe closer to 4 and 9% respectively. still, that is significant. am i figuring this correctly?
Old 06-24-2009, 03:16 PM   #2
At idle it only needs to make enough power to overcome engine friction, which isn't much at idle RPM and closed throttle. I can see A/C being as much as that.
Old 06-24-2009, 03:41 PM   #3
MPG impact is directly related to engine power.
Larger engines don't get affected as much by ac. I would venture to say that the MPG impact is about as noticable as the performance hit. That's what my experience has been anyways.
- Kyle
Old 06-24-2009, 03:42 PM   #4
Are there any cars that kick off the A/C when they need more power? I used to do it manually when climbing the steep hills in Providence in my 87 Sentra.
co de pen den cy
Function: noun
Date: 1979
Old 06-24-2009, 03:44 PM   #5
i think you're spot on there. i don't remeber my V6 olds losing that much. besides if the % was the same, obviously the loss in larger engines and lesser FE would not be as noticable.
Old 06-24-2009, 04:04 PM   #6
AFAIK, most modern cars turn off A/C at WOT.
Old 06-24-2009, 04:06 PM   #7
I think larger engines don't suffer as much... I tested this a year or 2 ago. Drove my truck on its daily drive, with the A/C on max for a week, then drove it with the a/c off and windows up for a week and noticed no difference in my mileage.
Old 06-24-2009, 04:14 PM   #8
Chryslers turned the a/c off under heavy loads in the 80's. I hated it. Hit a good sized hill and the a/c would shut off. I'd hate to have to drive it up a mountain in the summer...
Old 06-24-2009, 04:39 PM   #9
I hadn't considered that. Pretty ironic given where I live!
co de pen den cy
Function: noun
Date: 1979
Old 06-24-2009, 05:40 PM   #10
Yea, but you are in Florida too.
I have actually only needed to use mine a couple of times this year and mine makes no difference on the highway where 95% of my driving is.
Dave
GasSavers_GasUser is offline   Reply With Quote
New personal best today 96hb General Fuel Topics 14 05-29-2008 07:35 AM
