12-26-2007, 05:53 PM
A Beater of an Insight
So in effort to reform my gas guzzling habits, today I picked up a 2000 Insight 5 spd for dirt cheap. It was a former police impound that got auction off'ed. 203k on the clock, one busted driver's side quarter panel window and a small dent on the passengers side over the rear wheel cover. The yard claims that the battery pack might be dead but considering their general ignorance on the pack, overall fear of the car electrocuting them, and the the chopped up remains of another Insights in the yard I'm wondering if there could be some life in the pack.
The car started fine on its 12 volt, idles normally, clutch action was smooth but engaged close to the floor. Throw felt odd, 1-3 were tight, 4th a bit long and 5th longer still. Gates 1-4 felt fine, but 5th seemed to feel a bit stiff. It moved under its own power. Don't really recall what the batterys SOC read but there were no flashing lights. Made no strange noises, very slight ticking while it was warming up, but it had been sitting for a month so I figured that was dry lifter noise. No clue whether or not it has had the battery warranty work done on it or not, forgot to check the VIN plate for the punch mark
With that kind of mileage what can I expect to starting failing on me?
Thanks
12-26-2007, 06:47 PM
Congratulations!
In for some pics.
- UfoTofU
12-26-2007, 07:53 PM
Cool, everytime I see an Insight, I want to trade my CRX off. Can we ask what it ran you? Don't know if it is a hydraulic clutch, but if so, the shifting issues you are noticing could be that the clutch fluid is low/needs bleeding. If it doesn't disengage all the way, it will cause the shifting problems you have.
12-26-2007, 08:03 PM
I got it for about 2k. I think its a hydraulic clutch, I'll be going over everything next week. Pics will follow as soon as I can find my camera.
12-26-2007, 08:22 PM
not terrible for that new of a car. the battery's almost certainly buggered with 203k on it. bleed the clutch and if it doesn't fix it, replace the slave and if still not better, the master cylinder (in order of expense). I wouldn't worry about the shifting problem till you get the clutch figured out. if you are still having problems, find out whether it's cable or rod operated shifter. if it's cable, adjust/replace the cables. if it's rod, check the bushings.
-Russell
12-26-2007, 08:37 PM
honda stopped with cable clutches in 92. It's a hydro. You can take it to Honda and pay $75 to have it diagnosed. Your battery might be fine.
12-26-2007, 08:54 PM
Did it come with HOV exemption stickers?
Hrmm... Is a two seater HOV exempt all the time anyway? I mean, motor cycles are because they are at 50% or 100% capacity all the time. A 2 seater is always at least 50%  Depending where you drive in the Bay Area - it's nice to not pay through the HOV
And congrats on your find... I imagine if the batteries were buggered, you'd be getting some form of idiot light... Probably not like new though
11/12
12-26-2007, 09:17 PM
I wish  Doubt I could apply for em. But since it is a two seater who knows? HOV stickers would be icing on a cake.
I need to run it some more to make sure no idiot lights flare up. It needed a jump to start so I don't think the 12 volt had enough power to keep any DTC in memory. If they are any they will crop up after some usage.
Even if the batteries are fubar'ed 1L 3 banger shouldn't be too shabby in the FE department. 10x better than the Heep.
As for the shifter, I'm used to the Heep's stick; mile long throws with a direct hook up to the tranny along a heavy long throw clutch. The Insight is the first 5 speed FWD car I've owned so I could be misinterpreting its "feel". Its possible that its perfectly normal
Matt,
75 bucks covers a full inspection?
12-27-2007, 04:17 AM
Honda doesn't use hydraulic lifters. In fact, if you are not used to Japanese cars, you might be surprised to know that, for the most part, valve lash is adjusted manually (typically every 30000 miles). With this said, the engine might need a valve adjustment.
12-27-2007, 04:49 AM
If the batteries are shot, it'd be interesting to see what kind of mileage an insight can get w/o battery assist, but also without the weight of the battery pack.
Think inside the Box!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
What a difference a tire can make!
jwxr7 |
General Fuel Topics |
16 |
09-04-2007 07:07 AM |
got pulled over
jwxr7 |
31 |
08-27-2007 01:13 PM |
Hello All
GasSavers_MikeD |
3 |
07-23-2007 10:34 PM |
Hi
moboman |
4 |
07-06-2007 07:09 AM |
TSB-Technical Service Bulletin
Compaq888 |
General Maintenance and Repair |
5 |
03-20-2006 09:12 AM |
