A Beater of an Insight - Page 10 - Fuelly Forums
Old 03-05-2008, 09:31 AM   #91
GasSavers_Red's Avatar
Sweet thanks Zugy
Old 03-05-2008, 10:26 AM   #92
GasSavers_bobski's Avatar
Originally Posted by ZugyNA View Post
Do this by unplugging the sensor harness, warming up the engine, and creating a lean condition at about 2000 rpm for 1 or 2 minutes. Create a big enough vacuum leak so that the engine begins to slow down.
Unfortunately, most Hondas use a speed/density system rather than mass airflow to meter fuel. That means that a vacuum leak will simply boost the idle speed rather than turn the mixture lean.
Old 03-05-2008, 07:19 PM   #93
If I ran it hard would that net me a similar effect?
Old 03-05-2008, 08:14 PM   #94
The Toecutter's Avatar
Two off the wall ideas to make this car unique that may be more trouble than they're worth:
1) Turbocharge it. John Wayland rode in Willie Williford's Honda Insight that has a turbocharger installed in it running 5 psi of boost. 0-60 mph was about 7 seconds and there was no penalty in fuel economy if driving style was kept unchanged. You could go baiting Porsche Boxters, Audi TTs, and BMW Z3s.
2) Convert it to electric. The glider is perfect for making an 80+ mile range conversion using lead acid batteries due to its low weight and good aero.
Old 03-07-2008, 06:07 PM   #95
How long do the batteries actually function in the Insight. And what is the cost to replace when the time comes?
rangerbentman is offline   Reply With Quote
Old 03-07-2008, 07:04 PM   #96
Cost seems to range from anywhere from 5000-1200 bucks. Battery life I'm assuming to be around 150k as that is what they have been warrantied to.
Old 03-08-2008, 04:31 AM   #97
ZugyNA's Avatar
I think there are some commercial additives that will help prolong the life of lead acid batteries? Check out something for DC operated forklifts or golfcarts?
Old 03-08-2008, 06:26 AM   #98
You would have a hard time using such an additive with an Insight. The main battery pack consists of 120 sealed "C" size (IIRC) NiMH cells. Even if it were compatible with the chemistry, you would need to break down the battery pack and somehow evenly inject the additive into each battery cell.
I guess you could use it in the much smaller 12V lead-acid starter battery, but they likely cost less than $50 to replace, so what's the point?
Old 03-08-2008, 09:02 AM   #99
Exactly. Now if I replaced the pack with lead-acid or added on a lead-acid booster pack like Mike has then it would make sense to find such an additive.
Old 03-09-2008, 03:52 AM   #100
ZugyNA's Avatar
What will they think of next?
What a difference a tire can make! jwxr7 General Fuel Topics 16 09-04-2007 07:07 AM
got pulled over jwxr7 General Discussion (Off-Topic) 31 08-27-2007 01:13 PM
Hello All GasSavers_MikeD Introduce Yourself - New member Welcome 3 07-23-2007 10:34 PM
Hi moboman Introduce Yourself - New member Welcome 4 07-06-2007 07:09 AM
TSB-Technical Service Bulletin Compaq888 General Maintenance and Repair 5 03-20-2006 09:12 AM
