A Beater of an Insight - Page 9 - Fuelly Forums
Old 02-29-2008, 09:12 PM   #81
Compaq888's Avatar
wow...2k is quote a steal
Old 03-01-2008, 07:07 PM   #82
GasSavers_Red's Avatar
Thanks compaq888
Great weather to be wrenching today. Got the rear hatch struts replaced in the back, makes life much much easier now than the stupid broom rod.
Got a couple of quotes on pulling the dent out. Seems to range from 700-1500 for the thing. Most places don't seem to care that the body is made out of aluminum which worries me a bit.
Vacuumed out the inside, found 33 cents in change, an earring, salt shaker, speeding ticket, cancellation of phone service notification and an ATM receipt. Seat sliders badly need some lube. Drivers seat is fairly worn and stained. Going to try steam cleaning them else I was debating replacing them with S2000 seats if I can find them cheap.
Windshield will be replaced next week. I don't think $250 installed at my home is too bad of a price.
Was attempting to pull out what remains of the old quarter panel window, but the sealant is a pain in the neck to cut through. Going to try to find either a gasket cutter or some sharp blades to cut though it.
So far Rommie is starting up fine, SOC hasn't moved much as I've been starting it and moving it around a bit. Granted it hasn't really been used but seems ok.
Going to spend tomorrow cleaning out the harness around the front 02 sensor, see if that will patch it up.
Old 03-01-2008, 07:29 PM   #83
Compaq888's Avatar
Originally Posted by Red View Post
Thanks compaq888
I would keep looking for a better deal for windshields...I've heard of people paying $140 installed...use your money wisely to replace other things...
How about some pics of the Insight?? My imagination isn't that good and a picture is worth a thousand words...
Old 03-01-2008, 09:26 PM   #84
True true, but I have yet to fine a local place that would be willing to do the Honda under $250. Would love to get it lower though. Can't legally drive it or tow it anywhere far.
np, I have some old pictures posted up earlier
http://www.gassavers.org/showpost.ph...1&postcount=36
Need to give it a wash and take some new pictures soon.
Old 03-02-2008, 05:49 PM   #85
In between helping my dad put up the shed I got a couple of things done.
Replaced the front parking light bulbs, now my front emergencies work again. Tiny little things, utterly pointless, but hey it works now. And only cost a buck.
Tried to replace the tranny fluid but the fill plug seems like its welded itself to the tranny. Cheater bar didn't help so I've sprayed it with PB and later on I'll put it on stands and see if I can get some better leverage on it.
Played with the LAF a bit. According to the ECU & the FSM its slow and non functional, but I'm wondering if its possible to clean it? Figure it worth a shot before I blow 220 bucks on a new one. So far I've heard there are 3 different ways of cleaning one
1) Heating it up with a blow torch then quenching it to knock the carbon loose
2) Spraying the crap out of it with carb cleaner
3) Dunking it in acetone
The sensor is physically dirty and apparently there are some kind of vent located on top of the sensor that could get clogged and cause a similar problem. I am going to try to clear the vents first, then pull it out and clean it with something.
Old 03-02-2008, 06:53 PM   #86
MD2000's Avatar
FYI
Insight Central has just upgraded their forum software, and now has a search function that can use all of the standard search delimiters.
Much better ability to find stuff.
Mike Dabrowski
99mpg.com
MD2000 is offline   Reply With Quote
Old 03-03-2008, 07:31 AM   #87
GasSavers_bobski's Avatar
Originally Posted by wikipedia
Sensor failures
Normally, the lifetime of an unheated sensor is about 30,000 to 50,000 miles. Heated sensor lifetime is typically 100,000 miles. Failure of an unheated sensor is usually caused by the buildup of soot on the ceramic element, which lengthens its response time and may cause total loss of ability to sense oxygen. For heated sensors, normal deposits are burned off during operation and failure occurs due to catalyst depletion, similar to the reason a battery stops producing current. The probe then tends to report lean mixture, the ECU enriches the mixture, the exhaust gets rich with carbon monoxide and hydrocarbons, and the mileage worsens.
Leaded gasoline contaminates the oxygen sensors and catalytic converters. Most oxygen sensors are rated for some service life in the presence of leaded gasoline but sensor life will be shortened to as little as 15,000 miles depending on the lead concentration. Lead-damaged sensors typically have their tips discolored light rusty.
Another common cause of premature failure of lambda probes is contamination of fuel with silicones (used in some sealings and greases) or silicates (used as corrosion inhibitors in some antifreezes). In this case, the deposits on the sensor are colored between shiny white and grainy light gray.
Leaks of oil into the engine may cover the probe tip with an oily black deposit, with associated loss of response.
An overly rich mixture causes buildup of black powdery deposit on the probe. This may be caused by failure of the probe itself, or by a problem elsewhere in the fuel rationing system.
If the vents in the outer shield are clogged, that's obviously a problem. The 3 options you listed should deal with carbon build up, though I wouldn't quench the sensor - you're likely to crack the ceramic element. Lead, silicone and silicate poisoning can evidently be dealt with by heating up the sensor beyond the boiling points of these materials, though you should be careful to avoid boiling off the catalysts in the process.
Old 03-03-2008, 09:19 AM   #88
That really was quite a steal! I can't wait to see what kind of gas mileage this thing is able to pull off.
Old 03-03-2008, 06:00 PM   #89
IC is still a pain in the arse to find something technical. I don't know if its the nature of the vehicle, but in the Jeep community its cake to find technical component information.
Crap, so cooking it might not work if the sensor is simply worn out.
I need spring break........
Old 03-05-2008, 01:27 AM   #90
ZugyNA's Avatar
http://www.gnttype.org/techarea/ecms...O2sensors.html
If you are not able to make a change either way, stop the engine, unhook the sensor wire from the computer harness, and reattach your voltmeter to the sensor output wire.
Repeat the rich and lean steps. If you can't get the sensor voltage to change, and you have a good sensor and ground connection, try heating it once more. Repeat the rich and lean steps. If still no voltage or fixed voltage, you have a bad sensor.
If you are not getting a voltage and the car has been running rich lately, the sensor may be carbon fouled. It is sometimes possible to clean a sensor in the car. Do this by unplugging the sensor harness, warming up the engine, and creating a lean condition at about 2000 rpm for 1 or 2 minutes. Create a big enough vacuum leak so that the engine begins to slow down. The extra heat will clean it off if possible. If not, it was dead anyway, no loss. In either case, fix the cause of the rich mixture and retest. If you don't, the new sensor will fail.
What a difference a tire can make! jwxr7 General Fuel Topics 16 09-04-2007 07:07 AM
got pulled over jwxr7 General Discussion (Off-Topic) 31 08-27-2007 01:13 PM
Hello All GasSavers_MikeD Introduce Yourself - New member Welcome 3 07-23-2007 10:34 PM
Hi moboman Introduce Yourself - New member Welcome 4 07-06-2007 07:09 AM
TSB-Technical Service Bulletin Compaq888 General Maintenance and Repair 5 03-20-2006 09:12 AM
