'97 Civic running 14.2 Volts? - Page 2 - Fuelly Forums
Old 02-09-2009, 08:07 AM   #11
civic lover's Avatar
I check my car it runs at 14.3 volts.
Bruce you should keep a gas log. It would be nice to compare with someone that has an identical car.
civic lover is offline   Reply With Quote
Old 02-10-2009, 03:53 PM   #12
A "12 volt battery" puts out about 14 volts when no current is being drawn. It drops down under load to 12 volts or lower depending on the amount of load.
The voltage regulator keeps the battery at 100% voltage under no load conditions, so it stops charging at about 14.2 volts, and charges at anything less.
Old 02-11-2009, 03:48 PM   #13
Careful with your wording, the battery doesn't put out 14 volts. It's the alternator that gets the voltage of the system that high. The battery doesn't go above 12.6 normally, as said previously (although I don't think I've ever had mine that high, it's usually at 12.2 or so with the car off).
If you have a load that's dipping your voltage under 12 regularly, you need a beefier alternator and perhaps an extra batteries. I'm into car audio and we run into questions about this all the time. Kids can't be running 4,000 watts off of their stock electrical systems!
KU40 is offline   Reply With Quote
engine squeal skale7 Transmissions and Running Gear 10 10-20-2008 04:08 PM
The ideal car? fumesucker General Fuel Topics 11 05-23-2008 07:48 PM
Hi um, I am brand new to hypermilling. CryingStreetRacer Introduce Yourself - New member Welcome 16 05-15-2008 01:43 PM
? for dmm user's, monitoring lean burn rlprlp1 General Maintenance and Repair 4 12-17-2007 11:16 AM
1988 CRX DX Auto 116k for sale UfoTofU For Sale 3 09-26-2007 06:07 AM
