'96 Chevy Cheyenne 1500 - Page 2 - Fuelly Forums
Old 10-19-2010, 11:51 AM   #11
Re: '96 Chevy Cheyenne 1500
Well my Z28 got fresh fuel back in Feb. and I'm still jogging it around town once a month trying to burn it all up, which is hard to do when the tags and insurance are expired...
Next time around I'll be adding some fuel stabilizer.
The miata has premium in the tank but it's been in there for 2 1/2 years. Probably just going to jumper the fuel pump this spring and open a fuel line and just dump all the fuel out. Walbro 190 HP pump at 110psi fuel delivery should make pretty quick work of 5 gallons.
Then there's the SL1 that's been sitting on E for 8 months. Guess I'll get to that in a few years.
lol I have an addiction, I know.
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 10-23-2010, 05:07 PM   #12
The mystery continues.
I've yet to register/insure the truck so I'm still not sure WTF it is! I was certain it was a C/K 1500 but edmunds.com says they only came in 4.3L V6. So I click on C/K 2500 and there's a 5.0L option for regular cab like mine is, but the horsepower and torque are rated lower than what I researched and found for a 5.0L Vortec in a '96 Chevy pickup...
I gotta get to the bottom of this!
I bet it's a 2500 and the higher horsepower specs I read are inaccurate... but IDK, it'll light em up in 4th gear in the rain going 20mph with ease. Definitely lots of tq.
John
'01 KTM Duke 2
Old 10-23-2010, 05:08 PM   #13
Anyway, here's a picture.
John
'01 KTM Duke 2
Old 10-23-2010, 05:17 PM   #14
Feed your RPOs into this: http://lonestarthunder.com/m_rpo.php
or feed your VIN into this: http://compnine.com/vid.php
Seriously, that will eliminate all mystery (unless something doesn't match the results).
Old 10-23-2010, 10:42 PM   #15
I'll have to do this tomorrow. I have yet to write down the VIN or even look at it.
John
'01 KTM Duke 2
Old 11-30-2010, 04:49 AM   #16
Alright, I fed the VIN into that link and got all the info.
It is in fact a '96 C1500. Has the original type engine, 5.0L votec, and has always been a 5sp. Rear axel is 3.42, one wheel peel!
I filled it up about 2 weeks ago and been driving it a bit lately. Hoping to see at lest 16+ mpg out of it. Will probably be another 2 or 3 weeks before I need fuel again though.
I could not get the fuel filter off to save my life. I think I'm going to need to attempt the dremel technique. Scared though!
John
'01 KTM Duke 2
Old 11-30-2010, 05:52 AM   #17
That really stinks.
Is your fuel filter equipped with female nuts that mate to male flare nuts on the fuel line? If so, you can do it the suicidal way that I did.
I cut into my fuel filter's nut, parallel to the lines, not all the way down to the threads. After weeks of spraying with PB Blaster and hammering and wrenching, those cuts relieved the tension enough to make it possible to remove them.
If you have the time and patience, I recommend doing it by hand with a file or using a dremel cutoff wheel very slowly in a drill, to avoid making sparks. If you can think of any less dangerous way to do it, please do that instead. Maybe a nut splitter can crack the nuts without damaging the fuel line?
Maybe there's some way to evacuate all fuel from the line and filter by running something non-combustible through the lines?
CRX HF D15Z1 Cluster Issues GasSavers_maxpowers Transmissions and Running Gear 3 09-02-2009 10:47 AM
A/C Modification Idea therealtime Experiments, Modifications and DIY 11 09-18-2008 05:42 AM
ScanGuage II problems leetramp General Maintenance and Repair 6 06-10-2008 01:02 AM
New homepage Matt Timion Fuelly Web Support and Community News 11 08-02-2006 04:21 PM
A Giblet of Friendly Advice SVOboy General Maintenance and Repair 12 08-02-2006 12:35 PM
