94 eg hatch - Page 2 - Fuelly Forums
Old 10-30-2011, 04:39 PM   #11
Re: 94 eg hatch
Ok ill work the other issues first. I didn't know that it would though the MPGuino off.
Delsol_d15b is offline   Reply With Quote
Old 10-30-2011, 04:40 PM   #12
Lean Burn Mode
pgfpro's Avatar
Re: 94 eg hatch
Originally Posted by Delsol_d15b View Post
The idle is very smooth and right at 900. Yes the power is good as fare as i can tell (coming form DSMs). I tried adding timing at light loads but MPGs went down.
Good point on the cam setting. I thought about that a while ago but didn't investigated it do to rut running ruff. Ill check that out next.
I just changed the fuel trims. Ill report back latter them I drive to work.
Thank you for the help!
Whats your vacuum at 900rpm?
Old 10-30-2011, 05:29 PM   #13
Re: 94 eg hatch
I dont have a vacuum gauge. Its on my list of things to pick up.
Old 10-30-2011, 05:41 PM   #14
Re: 94 eg hatch
Ill post what the map is reading though. It should be close.
Old 10-30-2011, 07:56 PM   #15
Re: 94 eg hatch
Map pressure reads 20.9 inHG at idle. No change in MPG for inj settings.
Old 10-31-2011, 07:42 AM   #16
Re: 94 eg hatch
Ok timing is dead on. I have a new PVC on order. No vacuum leaks.
I know I have to be missing something....
Did my tune look good to you? How fare off is it off from yours?
Old 10-31-2011, 09:14 AM   #17
Lean Burn Mode
pgfpro's Avatar
Re: 94 eg hatch
Your tune looks good. You should be around 50mpg freeway. I will have to ponder this for awhile?
Old 02-29-2012, 07:27 AM   #18
Re: 94 eg hatch
drop your idle to 450, like the VX, I gained 5MPG with that, though my VX only does it with the lights and fan off... still..
VXrunner is offline   Reply With Quote
Old 02-29-2012, 08:14 AM   #19
Re: 94 eg hatch
I'd go back to fuel economy basics to start. Pump the tires to max sidewall, get the alignment checked. Are you running a short ratio trans or a vx/cx trans?
I exit lean burn when my life is at risk.
1998 Odyssey 24.1 mpg average
1984 crx project now on the road
hondaguy72 is offline   Reply With Quote
Battery tender chargers theholycow General Maintenance and Repair 3 06-29-2010 07:02 PM
electricyaris.com MetroMPG Electric and Solar powered 20 04-21-2009 02:26 PM
Coming to you from South Texas SOHC-VTEC Introduce Yourself - New member Welcome 2 05-06-2008 02:30 PM
California smog/registration question roadsterbum General Maintenance and Repair 8 02-23-2008 03:41 AM
More need for computer help Rstb88 General Discussion (Off-Topic) 2 01-31-2007 07:30 PM
