93 Civic VX -What should my mileage be? - Page 2 - Fuelly Forums
Old 01-14-2011, 09:16 PM   #11
Re: 93 Civic VX -What should my mileage be?
Sure I'll take some pictures tomorrow.
GasSavers_1stHonda is offline   Reply With Quote
Old 01-17-2011, 09:57 AM   #12
Okay I have the pix, but I don't know how to upload them.
Numbers are:
37820-P07-A00
670-109851
Old 01-17-2011, 11:38 AM   #13
imzjustplayin's Avatar
Numbers are:
37820-P07-A00
670-109851
Sounds like you have the right ECU, as for hosting the pictures, go to imageshack.us and then try to link to the page with the pictures.
Old 01-19-2011, 04:27 PM   #14
Okay well if the ECU isn't the problem, what could be causing my little VX to get such low mileage? My thoughts were the timing and O2 Sensor. Could it be something else?
No CEL for the O2. And it's the right model. However since the car has over 320k miles and the original clutch, the O2 might also be the original. Is it possible to take it out and clean it?
Old 01-19-2011, 04:37 PM   #15
Do you have the honda service manual? Use this:
http://rapidshare.com/files/43399660...nual_92-95.pdf
It's text searchable and I guess if you just look around inside the manual, you'll find a diagnostic procedure to try out.. All the suggestions I've made in this and other threads was based upon what I found inside of this book.
Turn your DPFI Civic/CRX into a CRX HF MPG machine for only $300 red civic standard For Sale 2 06-03-2010 02:26 PM
d16y7 with d15z1 head hondafreak93 General Maintenance and Repair 3 06-01-2010 06:19 AM
Air Intake System rebuild questions Darkelf General Maintenance and Repair 18 02-08-2008 06:05 AM
Blast from the past: Mobilegas Economy Runs? Spule 4 General Fuel Topics 8 11-20-2006 08:47 PM
Questions about PCV Compaq888 General Maintenance and Repair 28 06-09-2006 07:27 PM
