92 Civic VX Speakers size panels - Fuelly Forums
Old 05-01-2012, 11:31 AM   #1
sebass's Avatar
Hi guys. What size you speakers have you installed and what brands and models in rear side panels. Mine didn't come with speakers or panels for that matter but look i found wiring....yeayyyyyyyyyyyyyy. Any ideas how to mount 6x9 speakers in rear. Would 6 1/2 fit? What about speaker holes in side panels? Any idea. As always I appreciate everyone's input/comments.
Also found this
sebass is offline   Reply With Quote
Old 05-02-2012, 07:19 AM   #2
Re: 92 Civic VX Speakers size panels
6.5" can fit with the factory panels in place. You'll have to make something to mount the speaker to if you don't buy the insert. 6X9's are a bit too deep to fit. It's hard to hear the rears very well anyhow.
If it came without speakers the covers you have probably don't have a grille. You'd need those too.
I exit lean burn when my life is at risk.
1998 Odyssey 24.1 mpg average
1984 crx project now on the road
hondaguy72 is offline   Reply With Quote
Old 05-02-2012, 07:51 PM   #3
sebass's Avatar
Chris thanks my hommie!
I ordered 6.5 already so should be good to go. Got a great deal on them.
Old 05-12-2012, 01:16 PM   #4
sebass's Avatar
So I got my 6.5 Pio 3 way speakers and installed them in front as they are much better then what's in front. Front i moved to back and wired them to existing wire harness but NO SOUNDS comes from back. Checked head unit if front and rear speakers are at 0 meaning head unit sends to both not just front. Its does.
I'm assuming head unit was not wired for rear speakers. Why not beats me unless Honda dropped the ball and didn't wire it all the way to head unit.
Found out that head unit can only be removed with 2 7" thin pieces of sheet metal that need to be inserted to take tabs out from sides. Any other ideas how aftermarket stereo can be removed as i don't have at this moment thin pieces of metal? You guys think rear was not wired on head unit or it's honda wiring?
Old 05-12-2012, 03:58 PM   #5
add|ct's Avatar
Do you have a FSM?
'92 Civic VX, Canadian model
Old 05-12-2012, 05:58 PM   #6
sebass's Avatar
Hi guys. I'm struggling with understanding the wiring of my head unit to old factory plug and existing front and rear speakers wires. Also i figured it would be good to learn if i ever again need to do this myself. I really appreciate your help guys.
Short video on all the wiring and my confusion. Please help.
http://www.youtube.com/watch?v=LpmGqfRuLnQ
Civic wire harness identification
http://www.installdr.com/InstallDocs...PDF/466017.pdf
Sony CDXGT08 Wiring instructions
Pin Number / Wire Color / Function
1 White Left Front Positive
2 Green Left Rear Positive
3 Violet Right Rear Positive
4 Grey Right Front Positive
5 Blue/White Amplifier Remote
6 Blue Antenna Remote
7 Red Accessory 12 Volts
8 Black Ground
9 White/Black Left Front Negative
10 Green/Black Left Rear Negative
11 Violet/Black Right Rear Negative
12 Grey/Black Right Front Negative
13 Sky Blue Telephone Mute
14 Orange/White Illumination
15 Not Used Not Used
16 Yellow Constant 12 Volts
Source(s):
10 Year MECP Certified Car Audio Installer and 25 Year Certified Electronics Technician
Addict whas is FSM? Front side mounting? I just instaled them in same spot as my previous once. plug n play
Old 05-13-2012, 03:10 PM   #7
sebass's Avatar
Project "Add rear speakers" is 3/4 complete now. I have wired rear wires to head unit and rears are working great. I must say without rear with just front speakers regardless how good they are it sucks. 4 speakers is a must. I installed NEW Pio 3way 300W speakers in front and moved OEM Pio 2way to back. I think i will replace next week rears too with same kind as front. They sound great. I will post ghetto setup of rears as i don't have harness or grills yet...lol
Installed 195F Coolant Thermostat ... Reset ECU? cfg83 General Maintenance and Repair 13 04-06-2011 12:54 PM
Best $100 to spend on a 1980's amarican full sized car. GasSavers_Ryland General Fuel Topics 33 04-22-2008 08:41 PM
241 On the List popimp General Fuel Topics 26 08-03-2007 09:29 PM
2006 Toyota Camry LE rh77 Car Reviews 0 01-24-2007 08:17 AM
