92 Civic 1.5 engine work with CRX? - Fuelly Forums
Old 10-05-2006, 04:31 PM   #1
UfoTofU's Avatar
Anyone know if this is a MPFI engine, and if so if it will have MPFI swap parts that I could use on my 88 CRX?
Found a semi-local ad that has a FREE 92 Civic 1.5 engine with auto tranny.
They took it out for an engine swap. I am thinking about going and picking it up if it will have a compatible MPFI set up on it?
Also, about how much does the motor and tranny weigh together as well as separately?
- UfoTofU
UfoTofU is offline   Reply With Quote
Old 10-05-2006, 06:11 PM   #2
Matt Timion's Avatar
If you're asking if the MPFI parts will work... yes. The MAP sensor is in a different location, and the injectors are differnet, but that's actually a good thing. If you use obd1 (92-95) injectors you won't need an injector resistor box.
If you're asking if the engine will work, yes. to make the engine fit you'll need to use your current transmission, and swap one of the engine mounts.
The engine + tranny will be heavy.I think an auto tranny weighs like 70lbs. The engine should be around 200-300...
don't quote me on that though.
Old 10-06-2006, 10:03 PM   #3
GasSavers_Ryland's Avatar
my 92 civic tranny weights around 50-60 pounds? my new (to me) one is sitting out side, I lifted it up to the table with one hand, and was able to carry it without getty my cloths dirty, my '85 crx hf tranny I think is about the same weight/size, altho I have not set the two side by side to find out for sure what the differnces are exactly, I just know that they are small and light, and bolted to the engine you need two people to lift them comfertably, seperated I was able to lift and carry them either alone, altho the engine was a slight strugle because of the size and shape.
Old 10-06-2006, 11:45 PM   #4
I'm basing this on the weight of the HF tranny I bought last year. I think it was around 50lbs shipped.
Old 10-08-2006, 06:50 PM   #5
UfoTofU's Avatar
Got the free motor
Well here it is in all it's umm glory.
This is the part that I am interested in though :
It is a D15B7. Intake Manifold has the fuel rail as well as the 4 injectors.
- UfoTofU
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 08:48 AM
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 10:10 PM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 01:52 AM
