89 Wagovan transmission, what HF will work? - Fuelly Forums
Old 07-13-2006, 12:24 PM   #1
Hello: I am trying to figure out what year or years of HF transmissions I can use to put in my "wagovan". The more I look, the more confused I get. Here is what I've found;
-the diamater and # splines for an 88 is different than an 89.
-the Wagovan appears be the same gear box as an SX.
Here are some of my questions;
-Can I use a 89-91 HF without making any other changes, or will I need to change the flywheel, also.
-Is their any way to use a 87 or 88 HF transmission.
-Other than the hydraulic clutch, is it possible to use a CX or VX transmission from a 92-95?
I know several of you have put HF transmission's in your car's. Does anyone know the answers to these questions, or know of a reference source I can check out, to figure these answers out.
Thanks, everyone.
Old 07-13-2006, 12:36 PM   #2
Matt Timion's Avatar
Thanks, everyone.
If your car was made between 89-91, you can use a 89-91 HF transmission. You can use a 88 HF transmission if you swap out the clutch/flywheel/axles, but that's kind of a hassle.
The CX/VX transmission will bolt up, but the hydrolic clutch will be an issue for you. I believe the only difference between the 92-95 and 89-91 transmissions is the throwout bearing. Just use the appropriate one for the transmission you're using and you'll be fine.
The best bet is to just find a HF transmission and use your existing axles, etc. I put a WTB ad on honda-tech for you today hoping that someone has one. Since you're in Southern California odds are someone down there has an extra one to spare.
Old 07-13-2006, 12:44 PM   #3
Totally Awesome!!! Thanks for the information!
Old 07-13-2006, 01:29 PM   #4
GasSavers_civicminded's Avatar
Keep in mind that the 92-95 will only bolt to the block - not the frame. That one is a no-go, at least as a bolt-in.
www.onetruth.com
www.sohchonda.com
GasSavers_civicminded is offline   Reply With Quote
Old 07-13-2006, 01:41 PM   #5
Ah, didn't think about that... so it 92-95 will require custom mounts then too, eh?
If that's the case I'd say that going 92-95 tranny in a 88-91 is just too much work, especially since you have to convert to hyrdo as well.
Old 07-14-2006, 03:59 AM   #6
Moderator
GasSavers_DaX's Avatar
Yeah, best bet is to get an 89-91 HF tranny and use your pre-existing axles.
Old 07-14-2006, 08:41 AM   #7
Thanks for the help. It sounds like I just need to keep my eye out until I find one at a "cheapy" price I feel I can afford. At least being reasonably comfortable about what I need to look for is a great help.
Total Spent for 2010 is still not showing. fpage77 Fuelly Web Support and Community News 13 01-21-2010 04:48 AM
Vehicle Event History stevarino Fuelly Web Support and Community News 4 09-30-2008 10:03 AM
Distinction in 'garage' for cars we no longer own Smitty Fuelly Web Support and Community News 3 09-12-2008 07:50 AM
an increase of 20mpg cost me... chesspirate General Discussion (Off-Topic) 31 01-22-2008 04:22 AM
My idea Matt Timion Vegetable Oil and BioDiesel 8 09-07-2005 08:01 PM
