Originally Posted by TomO
...Taking in account of the differences in and under the dash between the two models, HF has no clock, usually no A/C (which means no A/C components under the dash,
My HF has both a clock and A/C. I know A/C was an option but I thought all came with clocks.
You can swap out the 90-91 doors for the 88 model doors and install pillar mounted seatbelts into a door mounted system (requires welding in one or two nuts per side)
My 91 HF has the door mounted seatbelts but also has all of the holes and nuts installed for pillar mounted, no modification required.
