88 CRX HF, bad fuel mileage - Page 6 - Fuelly Forums
Old 07-08-2007, 08:25 PM   #51
88HF's Avatar
I found the info here: http://www.accordinglydone.com/data/injectors.php
but now that I look at it, says 89 is same as 88 even though I read elsewhere they were different.
my favorite thread
Old 07-08-2007, 08:47 PM   #52
88HF's Avatar
Also here: http://www.importperformanceparts.ne...lus-acura.html
my favorite thread
Old 07-09-2007, 06:28 AM   #53
GasSavers_bobski's Avatar
According to HondaAutomotiveParts.com, HF uses the same injectors 88-91, but they are different part numbers than the injectors used by the Si. I know the Si, and most port fuel injected Hondas/Acuras for that matter, use 240cc/min injectors. I seem to recall reading that the HF injectors are 190cc/min.
Old 07-09-2007, 06:50 PM   #54
88HF's Avatar
Where did you read that? I'm just going by the only information I can find and the difference between 235 and 240 isn't that much. I don't see why these two charts would be wrong. I use that site also, I didn't like how they used to calculate shipping without telling me what it would be. Now they've fixed that.
my favorite thread
Old 07-11-2007, 05:52 AM   #55
I'm not sure. Probably posted on one of the CRX enthusiast sites. I seem to recall 240 being molded into the injector plastic, but I can't find my loose injector sets to confirm that.
Old 07-11-2007, 07:53 AM   #56
Moderator
GasSavers_DaX's Avatar
240cc/min is a common injector size for Civics.
Old 07-11-2007, 10:06 AM   #57
88HF's Avatar
Well, maybe if I could read Japanese, but there are no numbers on either set that I have.
my favorite thread
Old 07-11-2007, 12:35 PM   #58
Ah, k... I'm probably thinking of DSM injectors.
The 5cc/min difference could easily be accounted for by variations in stock fuel pressure. 2.1%... That's less than 1 psi at typical Honda pressures.
What is this stat? cavale Fuelly Web Support and Community News 1 09-03-2008 08:23 AM
E-85 and EPA rating zpiloto General Discussion (Off-Topic) 7 09-26-2006 07:04 AM
