40 MPG Hundai Coming... - Fuelly Forums
Old 11-13-2010, 09:26 AM   #1
...and the 1.8L engine weighs 74lbs.
http://www.freep.com/article/2010111...-m-p-g-barrier
Dave
GasSavers_GasUser is offline   Reply With Quote
Old 11-13-2010, 09:46 AM   #2
Re: 40 MPG Hundai Coming...
You misread that..
Powering the Elantra will be a new 1.8-liter four-cylinder engine that weighs 74 pounds less than the one it replaces and gets 18% better mileage in highway driving.
Old 11-13-2010, 09:53 AM   #3
Lean Burn Mode
pgfpro's Avatar
But that would be really cool to have a 74lb engine
Old 11-13-2010, 10:02 AM   #4
I think the engine in my motorcycle weighs more than 74 lbs. I seem to remember about 10 years ago reading about an engine Ford was experimenting with that was made of high temperature plastic (Teflon I think) that was supposed to be really light, and have a life of about 100,000 miles. (at which time the engine was replaced, not repaired)
Old 11-13-2010, 10:22 AM   #5
Lean Burn Mode
pgfpro's Avatar
My D16Z6 engine weighed around 200lbs.
I also remember Ford and their very light weight plastic engine. I'm trying to find some info.
Old 11-13-2010, 04:42 PM   #6
Yeah, until some perp opens your hood and picks it up and carries it away....haha
Dave
Old 11-14-2010, 01:51 AM   #7
eee
eee's Avatar
74 lb... That might be do-able. I'd like a 2 cylinder 1+ litre boxer engine! They're inherently balanced so you save the counterweight balance.
eee is offline   Reply With Quote
Old 11-14-2010, 04:47 AM   #8
I seem to remember that the 3 cylinder engine in a Geo Metro (BTW rated 43/52MPG new EPA) was light enough for one man to lift out of the car by hand, but I can't find the weight now.
--- Who actually uses the tiprtonic ?? --- trautotuning Transmissions and Running Gear 24 10-04-2008 11:30 AM
When filling up today to check my mileage I had an issue. HondaTorneoSiR Experiments, Modifications and DIY 2 06-12-2008 07:28 AM
radiator exit path with undertray lunarhighway Aerodynamics 5 06-04-2008 11:31 AM
Aerodynamics improvement Greybrick General Fuel Topics 0 04-10-2008 08:14 AM
Last Minute Tips for College? SVOboy General Discussion (Off-Topic) 27 09-13-2006 08:15 AM
