2010 XLE V6 Camry 12-16 MPG issue
I been getting since my first full tank of gas between 11-16 mpg and 17 mpg top on HWY driving at 55-60 mph. My stop and go commute is 3 miles but takes like 15 minutes time due to lights. Dealership performed oil change new filter 2 new tires shaved rotors alignment and maintenance less than 700 miles ago. I been using Shell 86 regular and plus to Sunoco 87 regular which gets me 62,68 and 95 miles on trip meter from 5.550g, 5.265g,5.716g of gas filled in the tank. So consistent amount used and same gas stations used. Took it to the dealership and had a full diagnostics and nothing of course came up. No engine lights no maintenance lights are coming up on the car. I have an ultragauge coming in tomorrow via mail. My hwy commute was 55-60 mph one at 50 miles of traveling and other one was 20 miles of travel and only saw 16-17 mpg avg come up. Now the weird thing is when I go down to empty gas tank light then fill it up and drive I get about 23mpg-20 mpg but then as I drive more than 5 miles it drops down to 18 mpg then by next day with additional 3 miles to work I get 15-16 mpg. Then averages later to 13-15 mpg till empty. I have no leak in the gas tank nor do I hear sounds from the engine. How is it I have the worst miles per gallon Camry in the United States??
I reseted my ECU by taking off the negative battery terminal for 30+ minutes and wiped it clean before starting my fuelly.com mpg tracking. If your skeptical on my driving habits I came form a Camry LE 1995 V4 130HP my first car and never really pass 1500-2000 rpms because I loved my car and didn't want to beat on it. It was 18 years old and never let me down across 3000 miles to CALI and 3000 miles back with 157,000 miles. Anyhow if anyone can enlighten me how to get at least to 19-20 mpg from their own experience please post a reply. I been losing a lot of sleep over this and love this car so much even though I'm not a car enthusiast. But efficiency and reliability is very important to me and finding the answer to this low mileage issue is priority. I drive very conservatively and even glide and feather the accelerator drive an average of 25-30 miles per hour city to 55-60 on hwy (only go 5 miles above speed limits, yes I'm that guy you pass all the time and I stay away from the speed lanes.). I keep my RPM between 1500-2000 rule and I'm seeing 12-13 mpg on my display. Even with the extra weight in the front with a V6 I keep my acceleration lower than my previous 4 cyl 95 Camry LE. Thanks in advance for any helpful input you anyone can give me.
I take both starting Odometer readings subtract it from the time of fuel up odometer reading then divide it by the total gallons driven. Tried the trip meter and divided by the total gallons driven. I note the gas grade and location of the gas station and keep my past 3 fill ups were very close and driving routes the same. Reseted the ECU and checked the filter my tire pressure and oil and had diagnostics done at the dealership and it passed. No engine or maintenance lights while driving come up. Gasoline tank is clean and no strange sounds from the engine. Warm up 30 seconds before driving.
