1993 Civic CX transmission?? - Fuelly Forums
Old 11-16-2006, 07:44 AM   #1
Send a message via AIM to Brian D.
I found one of these in a yard near me. Is this transmission worth taking? I have the HF with the shorter gears (49 state, I guess....not the taller ones that I'd hoped for). Anyway, what's the gear ratio for this CX? I'm wondering if it would be better for me.
Otherwise, should I rescue this tranny before they crush the car? Anyone need it? (Just not sure if it would be worth it to you after shipping).
-Brian in Virginia
GAS GSLR
Brian D. is offline   Reply With Quote
Old 11-16-2006, 08:44 AM   #2
Matt Timion's Avatar
I wasn't aware that the HF came in different gear ratios. I'd recheck that just to be sure.
The CX transmission is only good if you have a 92-95 Civic. It will NOT fit in earlier civics at all.... well, unless you want to hack and weld it on there, and then convert to a hydrolic clutch.
Old 11-16-2006, 09:01 AM   #3
Sure. There was a 49 state HF and "the other" model. The other model (California?) was the one that gets better mileage, due to a taller 5th gear. My '91 was that car. My (current) '89 is the former. This is why if you check the EPA estimates, you'll see 2 listings for the HF model (probably all between '88-'91. The worst part about it is finding out how to decipher which trans is which when it comes down to differentiating between HF's.
GAS GSLR
Old 11-16-2006, 10:02 AM   #4
Matt: The HF did come in 3 different ratio's. They had one for California, which was pretty close to the same as a CX, then they had a 49 state unit, which was the lowest and then they had a high altitude model, which I think was some other final ratio.
Old 11-16-2006, 10:20 AM   #5
kwtorbe's Avatar
Can't the CX transmission be used in a later civic like a '96-'00 civic? I know I am looking for one for my HX but I'm in Tulsa, OK.
kwtorbe is offline   Reply With Quote
Old 11-16-2006, 11:23 AM   #6
Yep.
Old 11-18-2006, 10:00 AM   #7
you can easily use it on 92-00 D-series civics, and you can make it work on 88-91 D-series civics if you do a cable-to-hydrolic clutch changeover... Hasport sells a kit. I don't think there is any hacking or welding involved.
jpciii is offline   Reply With Quote
Old 11-18-2006, 11:24 AM   #8
One of the mounts on the 92-00 transmissions are different from the 88-91, so there would need to be some sort of custom bracket made or purchased.
For the money required to it to work (cable to hydrolic kit AND the mount kit) you would be much better off just trying to find a California CRX HF transmission.
Miles driven for year. fpage77 Fuelly Web Support and Community News 1 09-01-2010 11:48 AM
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 04:13 AM
OBD 1 Cable Pinout CruiseControl General Maintenance and Repair 22 04-04-2006 03:08 PM
Alcohol fuel kjvman General Fuel Topics 9 01-26-2006 10:00 PM
New Camry Hybrid... cool display! Matt Timion Hybrid Vehicles 6 01-19-2006 05:29 PM
