1959 376mpg car :) - Page 2 - Fuelly Forums
Old 04-23-2007, 08:43 PM   #11
GasSavers_Ryland's Avatar
I suspect that the reason it's sat for as long as it has, is that it's not truely road worthy, and wasn't ment to be, alot of records like that were made on closed tracks, it just had to look from the outside like something socialy acceptable for the time, and that was it, top speed is most likely some where around 40mph, if even that.
Old 04-23-2007, 09:29 PM   #12
I have no doubt that it truly gets 376 mpg. It's an utterly impracticle, purpose built car made purely to achieve a record. Heck, there's cars out there that get thousands of miles per gallon, but those are purpose built cars to break records, and would be useless on the street.
Old 04-24-2007, 05:17 AM   #13
Moderator
GasSavers_DaX's Avatar
theclencher - are you the one with the two part question, Mr. Tigger-Fip?!?!
Old 04-24-2007, 07:19 AM   #14
Team GasMisers5!
landspeed's Avatar
Why would you fill the engine bay with ice?
Hypomiler
Old 04-24-2007, 09:12 AM   #15
I wonder if the ice was so they could run it with no radiator?
It looks like it comes with the specialized, low rolling resistance tires, on the drive wheels. Check out that tread depth.
Old 04-24-2007, 10:01 AM   #16
Must have been doing burnouts. :-)
Since they are not flat, I bet they are solid rubber. That would definitely help the gas mileage...
Old 04-24-2007, 10:06 AM   #17
Moderator
It looks like it has a radiator in the pictures, but it's packed with insulation and there are no vents cut in the side if the car to allow cross-flow. Hmmm.
Old 04-24-2007, 02:12 PM   #18
I see what you mean on the bead, but the bottom of the tire is not compressed or flattened like a flat tire would be. Maybe he put it on small blocks.
What a weird rig. It's a big go-kart with a car body laid on it...
Fuelly badge not updating for about 2 - 3 weeks Need Fuelly Web Support and Community News 18 07-01-2012 03:01 PM
VW Jetta fast riser coolbreeze General Fuel Topics 5 07-22-2009 12:25 AM
DIY: Wire Tuck!!! SVOboy Experiments, Modifications and DIY 11 09-21-2006 05:17 AM
Condensator orevgym General Fuel Topics 0 07-23-2006 11:25 AM
