15 vacuum guage pressure - Page 2 - Fuelly Forums
Old 01-02-2012, 09:26 PM   #11
Re: 15 vacuum guage pressure
Here's a link to interpreting vacuum gauge readings. I have a vacuum gauge in my '88 Escort also tee'd into the brake booster line. It runs around 20-21 in. vacuum at idle. Does the vacuum go above 15 in. on deceleration? It should. Mine goes to about 24-25 in. vacuum on deceleration. 15 is lower than I'd expect, but it will vary depending on your elevation. Vacuum pressure will drop about 1 in. per each 1000 ft. above sea level. A few years ago I changed the timing belt on the Escort and the vacuum dropped to around 16-17 in. vacuum at idle until the timing belt wore in a stretched some so maybe the valve timing was slightly off after the belt change?? Never quite figured out exactly why the change in vacuum after the belt was changed.
http://www.secondchancegarage.com/public/186.cfm
Hipermiler
#47 on my way to #1
Hey! Boss Man..... shatto General Discussion (Off-Topic) 0 06-27-2010 10:52 AM
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 03:48 AM
Beating the Baro... MAP reading trickery? GasSavers_RoadWarrior General Fuel Topics 4 03-06-2008 01:43 AM
Questions about EOC and automatic transmissions txe5502 Transmissions and Running Gear 14 06-08-2007 01:53 PM
