ZX2 Front Fender Skirts Completed and Results. 3/15/07 - Page 6 - Fuelly Forums
Old 03-16-2007, 07:45 AM   #51
Semi-retired OPEC Buster
BeeUU's Avatar
Looks nice. Glad to hear you have noticable results.
B W
BeeUU is offline   Reply With Quote
Old 03-16-2007, 08:29 AM   #52
Matt Timion's Avatar
Originally Posted by CO ZX2 View Post
Matt. I have spent considerable time on this project because I believed in it. It has proved to me to be a worthwhile investment of that time. I will be happy to provide more details.
However, I would like to modify the name of the thread (Colorado ZX2) to:
This new name would give a more accurate description of the content. I probably shouldn't have integrated this project into my Introduction in the first place, not exactly the best place for a tech project.
This thread has been around so long, I wonder if there are those who think they have seen it too many times already. Therefore, they don't bother to look at additions or updates.
Can you assist me with this change? I am not a computer whiz and all I have been able to change is the title within the thread. Thanks CO ZX2
Unsure who helped with the title change, but in the future it would be best to start a NEW thread instead of modifying and old one.
This thread was your introduction. Now it is a project thread. Also, when thread titles are changed it affects google's ability to properly index the page.
Old 03-16-2007, 10:14 AM   #53
CO ZX2's Avatar
Sorry, Matt. But I did address the reply to you.
Old 11-07-2007, 09:47 PM   #54
Mighty Mira's Avatar
Hi, I like how you've implemented the front wheel skirts. Could you give some details on the construction?
I'm thinking about using thin rubber material, perhaps inner tube, and perhaps thin aluminium for the frame. Maybe the whole thing could be rubber? I'd attach the rubber to the aluminium with sheet metal screws.
Mighty Mira is offline   Reply With Quote
Old 11-08-2007, 05:15 AM   #55
CO ZX2's Avatar
I did use inner tube rubber for my first version, sewed to the plastic. A lot of work and hard to get a flat piece of rubber from the inner tube.
Current version uses 1/16 flat sheet neoprene bought off ebay for the inserts. Also was able to simplify construction dispensing with the sewing operation, using Super Glue to bond the rubber to the plastic. Made the job much easier and better looking.
All-rubber covering would be too flimsy and would move inward onto the wheel and tire at speed. One of my first experiments showed that. Even the 1/16 plastic frame is not extremely rigid, good because it has some flex when the rubber moves and also easily returns flat. I use a small 1/2 inch plastic ball screwed to the skirt to contact the center of the hub cap to prevent inward deflection and take some of the load off the rubber insert when steering.
To attach skirt to fender I used hard thickwall plastic tubing metal screwed inside the fender lip. This tubing was intended for in-floor heating systems. Strong, thick, stiff and non-corrosive. Spaced the tubing outward some at the bottom to clear the tire better. Metal screws into the tubing attach the skirt. Only one screw into the fender surface at the front and one at the rear. Skirt removes easily in 30 seconds with just a screwdriver.
Current version has proven to be very durable and reliable in all weather and driving conditions (gravel roads, mud, snow, ice, -0* F temps). Current skirts have been on the car since the middle of last winter.
More pics and info:
http://www.gassavers.org/showthread.php?t=4200
http://www.gassavers.org/showthread.php?t=4379
http://www.gassavers.org/showthread.php?t=4428
Spent a lot of time thinking and fiddling with this project.
Hope some of this helps someone.
Old 02-02-2008, 09:28 PM   #56
Sorry for taking so long to reply, CO ZX2. I only just saw the reply now.
Thanks for the info, I will digest it slowly. I tried just plain rubber (actually pond sheet, but very similar to inner tube although flat), and it does ripple a bit but does not appear to get sucked in much towards the tyre, at least at speeds below about 80km/h.
I am not yet convinced that it is an improvement, although I am seeing my best fuel economy figures ever as a result of my mods+ driving. (i.e. 3.5l/100km).
Old 04-17-2008, 08:50 PM   #57
We did get our HighwayGlider's
Just one pair. They look OK, very shiny, very transparent. Will put them on this weekend if the weather allows; and will post how it goes. But in general, I think you just cannot go wrong with the idea of making your car more aerodynamic, especially at this price of literally a few bucks. Will post the pictures, too.
sy27295 is offline   Reply With Quote
