Will from Michigan
I drive an 89' Chevy Celeb V6 2.8L
Been using Acetone for 2 months now and I must say the best concentration I've used is <B>*EDIT* 1.75 ounces/10 gallons</B> of 87 BP/AMOCO gas. I've BARELY noticed an increase in MPG, BUT the acceleration power has gone WAY up!
I came on board from Indianagasprices.com (i think) and I was there thru google. I am an active member of Detroitgasprices.com
I seen the featured vehicle and have some questions about things I would be willing to try on my own vehicle.
Where can you find: Excel Plus oil additive?
And the things listed below I would be willing to try out:
Splitfire 8mm dual-core plug wires
Splitfire triple platinum plugs gapped at .030 instead of stock .040
195 degree thermostat
Goodyear Assurance Comfortread one size over stock inflated to 55 psi
<B>*EDIT 11-2-05* Acetone at 1.5 ounces/10 gallons of gas (THIS WORKS) I've been metering my acetone innacurately so I changed my original post to my ACTUAL measurements.</B>
~Will
Computer Specialist & longtime Shadetree Mechanic
-unknown
