Want to get all I can out of my Civic VX - Page 2 - Fuelly Forums
Old 07-26-2006, 01:11 PM   #11
GasSavers_civicminded's Avatar
Originally Posted by lmart665
On the highway I normally drive about 72-74 MPH. On the highway I have gotten around 46 (again, at 72-74 MPH).
I agree with the slowing down part - you should be able to get 60 mpg by just going 60 mph with little other modification.
Welcome to the board.
www.onetruth.com
www.sohchonda.com
GasSavers_civicminded is offline   Reply With Quote
Old 07-26-2006, 01:11 PM   #12
Matt Timion's Avatar
Plugs
Wires
Water Injection
Fuel Additives
Oil Additives
Aerodynamics (what do you recommend, where can I get it, or should I just build it myself)
Intake (Warm air or cold air, what type of filter)
Oil
Transmission Fluid
Water Injection (I read a little about it)
Hydrogen Boost (Do any of you know about this?)
PCV Valve catch
Oil Cooler
Tires (what kind of tires and where to get them)
ANYTHING ELSE
New plugs are good. NGK properly gapped.
New wires are good too. OEM wires are the best.
Most fuel additives are a waste of time and money.
Oil additives like slick 50 might help. I don't have much experience with that. Hopefully someone else can add their input.
Aerodynamics mods will really help. Undertrays, grille blocks, or anything else you can do to smooth it out are good. Basjoos has a thread about his aerodynamic modifications that are great.
Most people here use lighter oil and have noticed success (0w 20, etc.)
Same for transmission fluid.
I've yet to see any data for water injection for EFI engines.
For hydrogen injection even the commercial products have yet to provide any data to show that it works.
PCV Catch can will help with long term gas mileage by keeping your engine clean.
for tires get LRR tires. They are the tires used on hybrids. LRR means Low Rolling Resistance, so essentially it has less friction on the road. You might want to do like krousdb did and get light rims from a civic HX and put tires from a Honda Insight on them. They are lighter and have lower rolling resistance.
Besides that, I hope other people can give more info. Welcome to the site and we hope to see more of you around!
BTW, 45 MPG is "good." I always laugh when people call 45MPG low.
Old 07-26-2006, 01:30 PM   #13
krousdb's Avatar
krousdb,
I am very impressed with your mileage stats. 65 with your VX and 66 with your Del Sol?!? That's insane. I want to get to that point. I will do whatever I can. I have the money and the ambition. Do you have any other mods, besides aero kit, on your VX? What have you done to your Del Sol to get that kind of mileage?
Thanks again!
On both cars, as Matt mentioned, I had/have lightweight HX wheels and the OEM Insight tires. On the Del Sol I had a belly pan and grille block. I will have that on the VX as soon as I pass inspection. The key to high mileage for me is low speed and engine off coasting. On my daily commute, it takes 55 minutes to go 25 miles (each way), so ave speed is just north of 30MPH. Secondly, I live in a hilly region, so I plan my route where I can turn off the engine while going downhill and bump start before climbing the next hill. On my round trip commute, my engine is on only about 60% of the distance, 30 of the 50 miles. So that means that I coast for 20 miles each day.
The VX is much more of a highway cruiser than the Del Sol due to the tall gearing and the vtec-e lean burn. I have actually changed my route from 25% highway to 50% highway and still show slightly better results over the Del Sol. My highway driving is in a 55 MPH zone so I just drive the speed limit. At 55MPH, the VX is capable of 64+ MPG, even in on hilly terrain. I expect that flat terrain would be even better. With the belly pan and grille block, I am hoping for 67+ MPG at 55MPH.
Old 07-28-2006, 10:47 AM   #14
Temperature and Aerodynamics
Does anybody know where I can get rear wheel skirts and other aerodynamic equipment for my 1994 Civic VX hatch?
I also have a question about the temperature the car is running at. Here is a cheap replica of what my temp gauge looks like when the cars is fully warmed up:
--HOT
--MEDIUM
--THIS IS WHERE MY TEMP IS WHEN WARMED UP
--COLD
Is this normal? Does this effect FE? What temp thermostat should I get if this is, in fact, bad?
Thanks!
lmart665 is offline   Reply With Quote
Old 07-28-2006, 10:54 AM   #15
That's normal for hondas. I'm running a 195 thermostat and it's still that low,
Anyway, as for the skirts, make some!
Find some coroplast and get cracking. MetroMPG (darin) has a grrrreat diy on his side skirts.
Old 07-30-2006, 01:41 AM   #16
GasSavers_Ryland's Avatar
stock tires on the vx are 165/70 13" next time I buy tires I'm thinking about 155/80 13" they would be 10mm narrower, and depending on the exact tire, the tread contact patch might be even narrower then that, they are also going to be cheap and light, altho shoping around for as high of presure, and long of tread life as possible is going to be a small investment in time, another option if you can aford it, are the honda Insight rims, they are more of a disk wheel, more aerodinamic, and around the same weight as the HX rims.
the aluminum brake drums from the crx hf made in 1986 (I checked, 1986 really is the first year they did that as a stock part) and latter are lighter weight aluminum with iron lining insted of full heavy iron wheel drums, the insight drums might fit as well, but I've been told that they are not as wide, so you end up with a gap next to the backer plate.
spark plugs, I've had best luck so far with NGK v-power (stock plugs) copper plugs are more conductive/efficent, but don't last as long, platum plugs are "more efficent over the life of the plug" or more so, after that point in time that you should have changed them.
I took out all my injectors one at a time, and cleaned them, they were extreamly dirty, even after useing a fuel system cleaner, altho I don't think that those products hurt.
my grill is compleatly blocked off except for a 6x6" area right in front of the radiator, and with it being 100+ degrees here the last few weeks, the temp has not creaped up to high, replacing your thermostat with a hotter one will increase your fuel mileage, but it will also increase your emmitions output, so they could have made the stock car get better mileage, with a sacrofice to the enviroment by putting a hotter thermostat in, stock is something like 182F or something that seems a bit low.
when your o2 sensor wears out around 200,000 miles your check engien light will most likely not come on, the car will simply run a bit odd, the gas pedal will feel much less sensitive and your mileage will suffer, and that is the time to cash in your retirement plan.
driving has alot to do with your mileage, stay under 70mph, and it will go up a lot, shift at or befor your shift light comes on, and take it easy! when coasting take your foot off the gas, and leave it in gear, as long as the engine is turning over 1,100rpm (?) the fuel injectors are turned off (no fuel being burnt) altho you will slow down a bit, if it's a short coast it can be alot easier then turning the engine off all together.
I'm running full synthetic and feel it makes a differnce, 0W 30, and soon synthetic manual transmition oil.
my mileage is also in the 40-50mpg range, alot of highway driving, alot of it with tools in the car/extra weight, and I agree, 45mpg is low, I cringe if it gets down to 40mpg, because another 10mpg is another 100 miles on the tank of gas.
Mobile Page for Smartphones GTGallop Fuelly Web Support and Community News 1 02-23-2011 11:34 AM
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 10:10 PM
Gas price chart? reppact Fuelly Web Support and Community News 2 11-06-2008 02:35 AM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 05:36 AM
BMW C.L.E.V.E.R. Concept MetroMPG Fuelly Web Support and Community News 4 04-24-2006 11:59 PM
