this is how i did it - Page 2 - Fuelly Forums
Old 06-02-2008, 07:30 AM   #11
Yup, I'm gonna try and get the intake ports of my Escort's head copper plated before I put it back on.
Edit: yes brass might not be such a good thing in the fuel system, because the zinc in it in combination with copper promotes a different catalysation reaction promoting acetic acid and formaldehyde production rather than ketones and H2. So stick to copper parts as much as you can.
By the way, copper is meant to be a "bad thing" in fuel systems according to some experts. As far as I can nail this down, it's due to the tendency of copper to work harden and fracture... therefore use of copper line instead of steel and/or flexible lines is not good, because vibration will weaken it. So best practice would be to make sure your copper fuel heating coils cannot come under any mechanical stress, by isolating them from vibration as much as possible. So support the heat exchanger well and allow plenty of free play in connections to it. Make the in and out pipes short, connect with flexible fuel injection hose.
Old 06-02-2008, 09:00 AM   #12
Hmm...maybe a couple inches of rubber hose on each end of the copper would help isolate it.
Old 06-02-2008, 09:14 AM   #13
civic_matic_00's Avatar
you know what would be great? a canister (maybe 2" in diameter and 2 to 4 inches long) filled with copper beads or coper shavings where the fuel would pass through. this could effectively "treat" E10 passing through it before it reaches the fuel rail. the canister can be bolted to eliminate any mechanical play, secure it with rubber coated clamps to dampen any vibrations and voila - an E10 catalyst!
a fuel filter with copper lining or filter mesh could do the trick! LOL!
a thicker copper tube with threaded ends, with the caps that have 3/8" fittings. hmmmmm.....sounds like a good project!
civic_matic_00 is offline   Reply With Quote
Old 06-02-2008, 10:48 AM   #14
Originally Posted by chope View Post
make a 3/8 copper coil about 6 inches long and coil it around your radiator return line insulate it i used a beer coozie and metal tape and connect it to you gas line going to the injectors ..works best with fuel injection i got 62mpg in a 92 stealth r/t now everyone go save some gas if you get a huge increase like me you toss a dollar my way
pics please! so the copper line is just hollow and empty? are you moving any fluid through it? or are you saying route your fuel through this? is this safe? fire hazard?
did you also increase your tire pressure and are you using a scangauge?
civic ex
y7block
y8head
gripforce light flywheel
dc 4-1 header
Was getting about 30mpg (40%HW 60%pizza delivery city driving) - Up to 33.89 w 40psi tire pressure!
meangreen is offline   Reply With Quote
