There are other like me!!! - Page 2 - Fuelly Forums
Old 01-25-2007, 04:03 PM   #11
lovemysan's Avatar
rjr311, came through with the link for the gear swap. He's a neat guy.
http://www.rpi.edu/~carabd/gearswap.pdf
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 01-26-2007, 09:36 AM   #12
Semi-retired OPEC Buster
BeeUU's Avatar
lovemysan-
Many thanks!!! I have some reasearch to do now!!!
red91sit-
I will have the photos scanned soon, I am working on it!!!
B W
BeeUU is offline   Reply With Quote
Old 01-26-2007, 10:38 AM   #13
skewbe's Avatar
I survived the 5th gear upgrade in a cabbie. Took out a tall 5th gear from a gls at u-pull-it for cheap. The step from 4th to 5th was huge, but if you are on the hiway a lot then it is a decent compromise.
a ratio chart might help (note these are not all diesels):
http://www.4crawler.com/Diesel/VW_02...smission.shtml
Standard Disclaimer
Old 01-29-2007, 01:43 PM   #14
BeeUU's Avatar
Photos
Hey:
Attached are photos of my 1983 tercel re-nose work.
I do not have a picture of the first model. The first couple (num 2 and 3)I attached my "alterations" to existing bumper and grill parts. For the last couple (num 4 and 5) I removed the bumper cover and grill and relocated the turn signals. Number 4 had plastic sleds for an undertray, which did not last too long, it was not supported well. Number 5 was the best, had a plastic sled duct to direct air to the radiator and as you can see, I also added driving lights, the 100w high beams are not enough in upper Michigan at night..so I tossed in another 200w for fun, alternators became a disposable item after that addition. The last (num 6) was not completed, it sported a full nose tray that would stay attached and required only six attach bolts, it would have been a beauty.
Enjoy!!
ID:	161   Click image for larger version
ID:	162   Click image for larger version
ID:	163   Click image for larger version
ID:	164   Click image for larger version
B W
Old 01-29-2007, 04:13 PM   #15
Cool.
Old 02-09-2007, 06:39 AM   #16
BeeUU's Avatar
Mileage is going up
My last tank improved, I started experimenting with engine off coasting. Neat.
B W
