So Cal native in search of better miliage - Fuelly Forums
Old 01-28-2006, 09:11 PM   #1
I am new to the site, I am just a guy looking to get decent mpg on my bucket.
I am getting 19 mpg on the street. It isn't very nice.
Any help will be greatly appreciated.
I run full syntech oil,
new spark plugs and wires,
and new air filter.
thanks for any help that you guys give me
oh yeah it is a d16a6
HardSaltydogg is offline   Reply With Quote
Old 01-28-2006, 09:20 PM   #2
Is that the d16a6 I see you
Is that the d16a6 I see you talking about on h-t? I'm pretty sure you'll hit 13s, but with n/a it will be expensive, just boost a z6 or something, unless you want the pride.
In any case, somethings wrong, run compression and leak down, check your sensors. Throwing any codes?
Old 01-28-2006, 09:33 PM   #3
Matt Timion's Avatar
Looks like that is either a
Looks like that is either a d16a6 or a d15b2 engine with MPFI conversion. I'm guessing that because the car is a DX.
there is NO reason you should be getting 19mpg in that car. You should be getting at LEAST 30mpg mixed.
Is this car burning oil? Do you have any vacuum leaks?
I would do like SVO boy said and do a compression check on each cylinder. I would also check your brakes as sometimes they are adjusted incorrectly and drag constantly, which can kill gas mileage.
Old 01-28-2006, 09:36 PM   #4
yeah it is on h-t, but my
yeah it is on h-t, but my build up plans have been put on hold because I have a child on the way. I would like to get this motor in tip top shape though so I don't have any unexpected expenses. I don't know if it is throwing any more code after a small wire fix up. The wiring from the last guy who had this car is very poor, I have been thinking about replacing the harness, if that could be done.
Old 01-29-2006, 06:28 PM   #5
Compaq888's Avatar
Make sure you redo the
Make sure you redo the wiring. Even if the wiring is working it can be working bad. When I first got my car I had the compression test done.
So far I replaced...
Air filter, fuel filter, distrubitor rotor and cap, spark plugs, spark plug wires, tranny flush, radiator flush, idle adjustment, new tires, and other stuff.
Old 01-31-2006, 05:21 PM   #6
I found a vacum hose not
I found a vacum hose not clipped on, it brought my idle way down, now it is time to see if it helps
Old 01-31-2006, 05:25 PM   #7
Sweet, starting logging this
Sweet, starting logging this junk in the gaslog,
fuel log date showing another language absi Fuelly Web Support and Community News 1 01-01-2011 05:49 PM
Mileage icon for displaying on other forums/boards? Pete7874 Fuelly Web Support and Community News 7 10-24-2008 05:26 AM
