Noob with a Metro and a Yaris - Page 2 - Fuelly Forums
Old 07-26-2006, 08:55 AM   #11
ahhh so it is a separate item . . . got us again . . . well at least it is a nice implimentation using SD cards is a great idea.
After you break it in you might consider Synlube.com for the first and last oil change you will ever need. I did my xB at 3700 miles and am still getting used to the idea that I will not have to change the oil for 150,000 miles or 15 years if I keep it in one piece that long. My mileage speaks for itself - check my gaslog. I don't recommend Torco until you finish breaking it in and I am not sure about the auto tranny fluid but I am sure Synlube has something that will outlast the original fluid. Mine tachs about 3100-3200 at 60mph depending upon which speedo you believe to be accurate.
Old 08-29-2006, 04:07 PM   #12
2600RPM at 60mph.
ketel0ne is offline   Reply With Quote
Old 08-30-2006, 11:43 AM   #13
Originally Posted by ketel0ne
2600RPM at 60mph.
WOOW that's a lot lower than the xB at 60 I turn about 3050-3100 depending upon what you use for the speedo - digital or analog or GPS.
Old 08-30-2006, 12:26 PM   #14
My dash speedo and the SGII are dead even.
Old 08-30-2006, 02:37 PM   #15
Cool maybe the higher tire air pressure +9lbs is affecting my speedo but I have about a 3% higher reading on the dash speed and the odometer is about 9% lower than actual distance traveled.
