new comer to jdm - Fuelly Forums
Old 06-12-2010, 10:44 AM   #1
Send a message via AIM to civicricerx
Exclamation new comer to jdm
i just bought a 1985 civic crx 5 speed about a week ago. before i bought it, it looked like it ran n drove good for a 25yr old crx. i put it on the road yesterday when i went to drive it for the first time it being one the road, " the idol is being stubborn it holds steady at about 850rpms sometimes, when i go to try to hold the gas peddle at any rpm it doesn't hold n the rpms drops." i thought it would have be the fuel filter but i changed it n i found out i was wrong, i cleaned the carburetor its getting gas fine, i dont know what to do next besides map sensor i want to try to diagnose this before i spend 250 on a map sensor im just trying to figure out how i can get this beast running strong n spend the least amount of money i can so i can save money up for a swap. any lil bit of information helps n will be appreciated, n im willing to learn.
civicricerx is offline   Reply With Quote
Old 06-12-2010, 04:54 PM   #2
GasSavers_Erik's Avatar
If you have a carb, you won't have a MAP sensor (that was only for the fuel injected Si models). The carb base gasket on these engines typically develops cracks or you could have a cracked vacuum hose.
There are two fuel filters- one up by the carb and one under the car just in front of the tank.
You can get lots of info on 84-87 civics and crxs at: http://www.redpepperracing.com/forum...p?showforum=32
Happy Opposable Thumb Day! GasSavers_maximilian General Discussion (Off-Topic) 3 06-22-2009 06:11 AM
clutch or neutral Kuripot General Fuel Topics 10 05-28-2008 05:50 PM
cuts in my rear bumper thisisntjared Aerodynamics 13 07-04-2006 04:50 PM
What is your favorite bulletin board software? Matt Timion General Discussion (Off-Topic) 5 03-30-2006 05:43 PM
airflow - is more or less better? Matt Timion General Fuel Topics 14 10-01-2005 02:57 PM
