Originally Posted by mnstrvx
Hi everyone,
I don't know how some of you folks are getting incredibly high MPG figures? I went through a tank of gas already, but for a good duration of time the car was idling as i was "diagnosing" things under the hood (also changed fuel filter and spilled some fuel). not to mention the fact that the tire pressure was incredibly low. I still got about 420 miles to the tank (I was kind of disappointed). this was all primarily city driving. I was doing a lot of above 2,000-2,500rpm shifting (until i read some more threads regarding shift points).
so, any advice would be greatly appreciated? I would love to see ABOVE 50mpg (500+ per tank full).
Okay... you do know that your tank is 10.0 gallons, right? So 420 miles on a tank (how many gallons did you fill up with? Probably less than 10) is probably mid 40s. It's very easy to get good gas mileage in the VX. You don't have to do anything too fancy and there are some key things you should know.
0. The more you brake, the more fuel you use. Try to drive in such a manner to avoid slowing the car down more than necessary. Fuel saving is all about conservation of forward momentum. Roll baby roll! (Coasting in gear is less efficient than coasting in neutral. Leave it in gear if you are coming to as top.)
1. When the engine is cold, the VX gets piss poor gas mileage. If you are doing lots of short trips and you're not seeing the temp needle get close to the little thermometer picture thing then you're never going into lean burn and are generally using lots of fuel.
2. Once the engine is warmed up (the temp gauge needle is just below the temp picture) accelerate slowly and shift at RPMs that will have you pulling from 1000 or 1050rpms after you have shifted. No reason to shift at higher RPMs, unless going up hills.
On flat here are my shift points:
1st and 2nd gear @ 1500rpm
3rd and 4th gear @ 1200rpm
5th gear @ 1100rpm.
3. Don't drive over 65mph. Speeds between 30mph and 55mph in 5th gear will get you the best mpg.
If you follow the above points while accelerating with a feather foot you will have mid 50s or I'm a Scottish terrier (unless you do lots of short trips and lots of city driving). The VX does not shine in the city, unless you learn some more advanced techniques.
Okay, on to more advanced and high falutin' feats of fuel savings beyond feather footing for when you are doing lots of short trips with cold starts and/or city driving.
The first five minutes your engine is warming up uses tons of fuel. One way I fight this is by employing the tried and true technique of pulse and glide (tried and true at least for this car). I'll get up to slightly higher than my desired speed and then turn my car off and coast for awhile, then I'll bump start the car and repeat the process. I'll do this until my temp is up, at which point, if your car is running right and your head lights and A/C aren't on, you should idle at 500rpm in neutral negating the need for turning your engine off and coasting to save fuel. Coasting in neutral when the car is warm is an easy way to save fuel.
In the film Wall-E there is a scene that makes a very nice and simple analogy of pulse and glide. Wall-E is in outer space holding onto a Fire Extinguisher. He fires the extinguisher to propel himself forward.. then glides for awhile.. and then repeats to propel himself forward again. Same principle on the road.
To save fuel while the engine is cold employ the pulse and glide method:
Accelerate in the highest gear possible to just above your desired speed, then put in the clutch, wait a half a second or so, kill the engine, wait another half a second, turn it back to ON position (leaving the engine off) and coast in neutral for as long as prevailing traffic and your patience will allow. Then bump start it. You should avoid bump starting in 2nd gear, and definitely not in 1st gear! There are certain speeds that correspond to certain gears you should bump start in.
Speeds that correspond to the appropriate gear to bump start in:
5th gear; any speed above 13mph.
4th gear; between 9 and 13mph.
3rd gear; between 4 and 8mph.
2nd gear; between 2 and 3mph.
1st gear; never.
It's tricky to bump start in 2nd gear without causing a knock or lurch so I advise against it. Use your starter if you are going this slow.
If there is any kind of lurch or knock sound when you bump start you are doing it at too high a speed for the gear you are trying to do it in and/or letting the clutch out to quickly!
To bump start: make sure your ignition is in the ON position. Put in the desired gear and let the clutch out as if you were doing a normal shift. If you do it too slow it will not work and if you do it too fast it will cause a knock or lurch which I don't think is good for the engine or tranny. As soon as the ignition catches, IMMEDIATELY put the clutch back in and engage the appropriate gear for your driving speed. Immediately putting the clutch back in will help prevent any damage being done to your engine or tranny.
Disclaimer:
I have no knowledge of the ill effects on the engine or related components from bump starting properly on a cold engine. I've been doing it for a year (even in winter) and while I had some undesirable effects for a short while (I was having faulty alternator issues), in the last several months the car has been purring like a kitten.
City driving.
1. Saving fuel in the city environment is all about LOOKING AHEAD and paying vigilant attention to what the traffic lights ahead of you are doing and more importantly what traffic ahead of you is doing. The better you can predict what's going to happen in front of you the more fuel you have the potential to save. It's all about ROLLING up to the traffic lights! Let the other cars accelerate by you only to have to slam on the breaks for the red light. Half the time you'll roll through the green light that you gave enough time for the red light to become, while the other cars have to get going from a stop. Avoid non thinking REACTIONARY driving. Employ the PROACTIVE model of responding ahead of time to what people in front of you are doing. Keep as much distance between you and the cars in front of you without keeping enough distance for someone to pull out in front of you.
2. Accelerate slowly and shift at 1500rpm from 1st and 2nd gears. When you are going fast enough to keep up with traffic coast in neutral for a bit (or with the engine off if your engine isn't warm yet) until you need to accelerate again to keep up with traffic.
3. Remove any extra weight from your car that you don't absolutely need to haul around with you. The VX is a very light car. Any extra weight has more negative effect on gas mileage than in other cars.
I encourage others to challenge, disagree or revise any of my points!
Thanks.
