Originally Posted by TomO
10.5 is all the higher I would go and still be able to stay with 87 octane.
You don't really want to mess with the stroke on the D15Z1, it sits right at a rod/stroke ratio of 1.62 which is perfect for low resistance rotating as well as lateral pressures of the piston.
If you really want to increase the FE of a VX, invent and aperture style throttle body. It would offer better, less restricted flow of air into the intake manifold.
aperture style TB - similar to a camera shutter? sounds like a good idea if you could get it to flow like a velocity stack for all throttle positions...I should start tinkering with this idea...
*wonder if smaller multiple throttle bodies would work...have them open up sequentially;
say you have 4 TB's:
full throttle - all 4 full open
freeway 65 MPH partial throttle - 1 full open, 3 full closed
you would choose how many TB's by sizing them such that 1 TB fully open would match power for freeway cruising.
