New 2013 Fusion Hybrid Driver - Fuelly Forums
Old 11-20-2014, 01:00 PM   #1
Question New 2013 Fusion Hybrid Driver
Hello Fuellies,
I am new to fuelly.com
I just purchased a new 2013 Fusion Hybrid in September 2014. Until the cold weather hit, I was averaging 56 mpg UK (47 mpg U.S. or 5L/100km) over the course of 6000km (3700 miles). I noticed that the last 2 fill-ups (the only two I have entered) averaged 49mpg UK (41 mpg US, 5.7l/100km) as the weathered dipped below freezing. I would like to know from other hybrid owners how bad a hit their fuel economy takes when more frigid temperatures hit.
Amplitech is offline   Reply With Quote
Old 11-20-2014, 01:49 PM   #2
I can't say how bad a hit it was when I had the Prius. It's been awhile since then and the winters were also mild. Do you have data for the previous car? The percent drop it experienced for winter should be close for what the Fusion will experience.
I think the hybrid has active grill shutters. Do they close up in cold temperatures to help with warm up time?
Old 11-20-2014, 02:11 PM   #3
About a 10% decrease seems normal for any car, not just hybrids, when the temp drops. Although in midwinter, December, Jan/Feb I expect it to be closer to 15% maybe even 20% if you start the car for defrosting etc.
Old 11-21-2014, 06:43 AM   #4
I would also expect a larger drop with a hybrid. Their main tactic for saving gas is shutting the engine off, which is going to run more in winter to keep itself and the cabin warm.
Old 11-21-2014, 07:05 AM   #5
Very true, also battery performance is reduced in cooler temps is it not? So that will have to be charged more often too.
Old 11-21-2014, 11:47 AM   #6
Yes, the battery is affected by the cold. It reportedly warms up quickly though. Plus they are mounted within the trunk or cabin space. So they won't lose heat as quickly as the engine out in the cold.
