Well its more like 3600 lbs. Less now, I have removed about a 100 lbs In the front. The later caprice (4000+)had a lot more glass, and more crash structure. I think it is fairly areodymanic. I have removed 95% of the trim on it. The nose on it is only 18 inches tall. Only the headlights, and the bumper, push against the wind. The windshield is fairly upright, but if I Make a custom hood that is raised up 6 inches at the base of the window it will help. My fuel pressure is 11.5 pounds, and I have it set high as it will go. I can double that at least. I have read about cameros and the heavy Buick Roadmasters with tbi that get 25-30+ mpg and they dont even have bellypans or wheel skirts. The underbody is horible on these cars (like pickups) and I think they would greatly benifit from belly pans.
Driving around here is mostly 50 mph with a stoplight every mile. Theres no hills at all. Yes I read about the Town car guy, and the laser, I am really slow about working on my car. It took 2 years to Change engines. (a weeks worth of work) because I am at work all the time. I have only driven it 3000 miles with the new engine, and my best mpg is 15. Mind you thats with a transmission that is shifting no sooner than 2500 RPM and its not broken in yet, and the heads and cam on this engine are actually meant for a carburated puckup. It has 8.5 compression ratio. It has a lot of potental, but I like it. You guys are too skeptical! Gosh!
