...just bought a VX - Page 2 - Fuelly Forums
Old 11-19-2007, 09:00 AM   #11
smccall's Avatar
Originally Posted by vxhatch View Post
Thanks everyone. The car is now inspected, tagged and titled. It's sitting on 155/80/15 Kumho tires on stock rims. Started on some slightly overdue PMS last night and pumped the tires up to max rated (42psi). Lean burn seems to be working as I when I push on the gas, I can feel a slight pause before the power comes on. I will start to track FE once I start to drive the car regularly.
Doug
How do you have that size tire on a VX rim thats only 13 inches? or do you mean 155/80/13?
Old 11-19-2007, 09:37 AM   #12
GasSavers_vxhatch's Avatar
Yes 155/80/13. Tires are fine for now, but will definitely look to go w/ stock size once they need replacing.
Doug
GasSavers_vxhatch is offline   Reply With Quote
Old 11-19-2007, 10:49 AM   #13
smccall's Avatar
I'm about to get some from Walmart. If I remember right, they were 30 bucks a piece for the 175/70/13.
Old 11-19-2007, 11:00 AM   #14
I believe the stock size is 165/70/13, $30/per sounds appealing tho.
By the way, I just found some posts from my car's previous owner, NickF829. Looks like he was unable to get close to the FE, other VXers have reported. I hope to improve on his results...
Doug
Old 11-19-2007, 11:14 AM   #15
smccall's Avatar
You and me both. If i can crack 50, that would be great.
Old 11-19-2007, 02:35 PM   #16
panamacolin's Avatar
I hav broke 50 but thats if I drive under 70...I drive around 75 on the interstate most of the time and get between 44-47 mpg.
Welcome to the site! Wondering how much you paid for your VX?
panamacolin is offline   Reply With Quote
Old 11-19-2007, 06:42 PM   #17
PM sent
Old 11-19-2007, 07:34 PM   #18
smccall's Avatar
Congrats on your VX vxhatch and thanks for car info.
Old 11-20-2007, 01:00 AM   #19
garyhgaryh's Avatar
The slower you go the better your mileage. If I go around 75mpg, I get about 47mpg. I get mid 50's if I stay at 60mph and draft trucks. And this is on a California VX with no lean burn mode.
garyhgaryh is offline   Reply With Quote
Old 11-20-2007, 07:05 AM   #20
smccall's Avatar
Hey garyhgaryh, I have a red Cal Fed VX too. TomO has explained a way to convert ours to achieve Lean Burn. Do you plan on making this change as well? What all have you done to yours to get mid 50's?
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 11:54 PM
WTB: VX Parts Wandering Albatross Wanted to Buy 3 07-30-2007 07:15 PM
Hello All GasSavers_MikeD Introduce Yourself - New member Welcome 3 07-23-2007 11:34 PM
Drafting 18-wheelers....revisited Brian D. Hypermiling 26 05-22-2007 02:51 PM
