It's Bunger - Fuelly Forums
Old 03-01-2006, 09:33 AM   #1
Bunger's Avatar
s I should really properly introduce myself. For those of you that don't know me, which is most I suspect, my name's Lee and I hail from northern California. I work as a DBA for a local oil company and spend most of my time trying to stay out of tro
Well, I guess I should really properly introduce myself. For those of you that don't know me, which is most I suspect, my name's Lee and I hail from northern California. I work as a DBA for a local oil company and spend most of my time trying to stay out of trouble.
For most of my automotive life, about 10 years now, the last thing on my mind was increasing my mileage. Until recently, I had strictly been a hard core racer at heart (I don't plan to give it up yet!). I've done about everything from checking the air pressure in my tires to rebuilding my engine and about EVERYTHING in between. I've also spent my fair share of time behind the wheel (SCCA, NASA, CSCC), as well as being a mechanic for my regional SOLO II CPS champion.
One good thing about coming from a racing background is that I know a good deal of tricks when it comes to freeing up horsepower and reducing drag and weight. These areas can all be applied to increasing your MPG, where normally you are trying to eek out those last few HP, you can now gain efficiency.
Now if anyone ever has an automotive question, feel free to ask, and don't worry if you think it sounds trivial or lame, I have 4 sisters who all go to me for automotive advice, so I've about heard it all.
Thanks Matt for inviting me over to your site, I hope in the years to come I have plenty to learn as well as bring to the table.
-Lee
Anger is a gift!
- Zack de la Rocha
Old 03-01-2006, 12:57 PM   #2
Welcome
Welcome to the site, Lee. By the way, do you have a specialization in imports or domestics? We have a wide range of cars in the "Gassavers Garage", but most are Honda/Acura. Right now we're trying to figure out exhaust diameter, backpressure, and muffler style for best economy (mostly in Hondas). Large, free-flowing exhausts probably won't help because of the requirement for some backpressure. Any experience in this area?
Old 03-01-2006, 05:24 PM   #3
Bunger's Avatar
My biggest specialty is in
My biggest specialty is in Honda / Acura... but I've owned my fair share of classic Mustangs as well.
As far as exhaust diameter, backpressure and muffler style. I can help you out with that probably. I'm assuming that most everyone here is dealing with NA motors (not turbocharged) to start with. What you would want to do to obtain the greatest gains from exhaust is to have the least amount of backpressure while keeping the port velocity at the right speed. People often get confused about this, too big is bad because of the low port velocity, not the lack of backpressure.
If there isn't one already, we should probably start a thread on this subject.
Anger is a gift!
- Zack de la Rocha
Old 03-01-2006, 07:08 PM   #4
Thread
We could resurrect this thread:
http://www.gassavers.org/forum_topic...l_economy.html
Old 03-01-2006, 07:11 PM   #5
kickflipjr's Avatar
we have had some
we have had some backpressure talk.
theard 1
thread 2
(EDIT: looks like i am slow again)
2008 EPA adjusted:
Old 03-01-2006, 07:19 PM   #6
Re: we have had some
I'm usually the one that takes forever getting the wording right, and fall short of the quote. Wow. :-)
Old 03-02-2006, 01:33 AM   #7
Bunger's Avatar
I replied to this
I replied to this thread:
Sorry bout the novel.
Anger is a gift!
- Zack de la Rocha
Old 03-02-2006, 03:25 PM   #8
FE nut
diamondlarry's Avatar
Re: I replied to this
I thouroughly enjoyed your "novel." It sometimes takes a few extra words to explain things right and so it can be understood.
2007 Prius,
Team Slow Burn
Old 03-02-2006, 05:03 PM   #9
Bunger's Avatar
Thanks again for the kudos,
Thanks again for the kudos, thank god it made some sense considering the time of day I wrote it. =)
Its rather interesting to me that almost every thing I've learned about making an engine produce more horsepower and be used to increase its mileage. For instance:
Throttle body:
Power: Make it bigger for less pumping losses at greater CFM.
Mileage: Make it smaller so the throttle plate is at a lesser angle of attack and thus reducing pumping losses.
Cam Gears:
Power: Move the power band up for more horsepower.
Mileage: Move it down to increase efficiency at cruising RPM.
I would be interested to see the results on a non-VTEC engine with adjustable cam gears. I'm not sure how dramatic of a change you would see on a VTEC engine, but I bet there are a few MPG to be found in a non-VTEC one.
Anger is a gift!
- Zack de la Rocha
Old 03-02-2006, 05:05 PM   #10
How much are cam gears for a
How much are cam gears for a d series?
What's the smallest tb to be used, the 40mm cx, vx, hf?
Tags in SMS messages elliottcable Fuelly Web Support and Community News 1 12-15-2011 12:28 PM
fuel.ly links broken quantumslip Fuelly Web Support and Community News 3 12-08-2011 12:41 AM
Scan Gauge Keen4Green General Fuel Topics 13 04-30-2010 01:44 PM
Request for more detailed avg mpg graph danieljmick Fuelly Web Support and Community News 1 02-02-2010 11:13 AM
Duel Fuel heating system GeoMetry General Discussion (Off-Topic) 0 04-16-2006 10:03 AM
