It's Bunger - Page 2 - Fuelly Forums
Old 03-02-2006, 05:26 PM   #11
Bunger's Avatar
Cam gear should be about
Cam gear should be about $50-60 shipped.
I think the CX/VX/HF TB's (the are all the same size... I was using a VX one on my HF engine before because I liked the cleaner look of the throttle body mounted MAP sensor) are around 40mm... damn small, I'll bust out my caliper when I get home and measure it.
I do know the other TB sizes off the top of my head:
D15/16 = 55-56mm
b18a / first gen b16a = 58mm
second gen b16a / b16b / b18b / b18c1 = 60mm
b18c5 = 62mm
If the CX/VX/HF one is really 40mm... that's a HUGE difference in area... as its Pi * Radius squared...
40mm diameter = 12.6 cm2
60mm diameter = 28.3 cm2
That's a cross sectional increase of 224%!!!
Anger is a gift!
- Zack de la Rocha
Old 03-02-2006, 05:29 PM   #12
It is hugely different, yep.
It is hugely different, yep. I have a d15b7 tb I'm going to use now until I can get all the cx stuff. The ports don't match well otherwise so I'll try and go all cx head/im/tb soon and get rid of the 56mm b7 stuff.
Old 03-02-2006, 05:40 PM   #13
Bunger's Avatar
I'm not sure, but is the CX
I'm not sure, but is the CX head the same casting as the HF?
Anger is a gift!
- Zack de la Rocha
Old 03-02-2006, 05:48 PM   #14
I believe so.
I believe so.
Old 03-02-2006, 06:19 PM   #15
Bunger's Avatar
I wonder if the cams are
I wonder if the cams are ground any differently. If I had one of each I could get them profiled. And on that subject, how bout a custom mileage grind?
Anger is a gift!
- Zack de la Rocha
Old 03-02-2006, 06:20 PM   #16
MetroMPG has mentioned
MetroMPG has mentioned someone who does custom cam grinds for metros that has an mpg set up.
Tags in SMS messages elliottcable Fuelly Web Support and Community News 1 12-15-2011 12:28 PM
fuel.ly links broken quantumslip Fuelly Web Support and Community News 3 12-08-2011 12:41 AM
Scan Gauge Keen4Green General Fuel Topics 13 04-30-2010 01:44 PM
Request for more detailed avg mpg graph danieljmick Fuelly Web Support and Community News 1 02-02-2010 11:13 AM
Duel Fuel heating system GeoMetry General Discussion (Off-Topic) 0 04-16-2006 10:03 AM
