Introduction and Questions - Fuelly Forums
Old 05-10-2007, 07:31 AM   #20
CoyoteX's Avatar
Lowering a Metro is pretty easy as long as you have a good way to cut the springs. The rear ones can be taken out to cut, just take the 2 bolts off the top of the strut tower and jack the car up till they are free. Don't take the center bolt out of the rear struts or it will be a pain to get back together.
Front ones just take the center bolt out and jack the car up. There is enough room to cut the springs while they are still on the car. I guess you could take the 2 lower bolts out of the strut after the spring is unloaded and take the struts/springs off the car. That would be a good time to put the offset bolts in there so it can be aligned easily. The car will need to be aligned after you get it sitting at the height you want. Mine was off by like 5 degrees camber after lowering it to within 1/2 inch of the bump stops. That will wear your tires out much quicker than normal.
If you want to put 13 inch wheels on it the proper way is to take the 10mm studs out and redrill the holes for 12mm wheel studs. There are some lug nuts that are bigger than the stock ones and can let you use the 13 inch wheels with the 10mm studs but I have no idea where to find them. Drilling out the holes and fitting 12mm studs is a pretty simple job really.
